| thenewwazoo |
Feb 20 2010, 09:37 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California |
My (fairly new-to-me) megasquirted '74 2L is running warm on the highway, and I suspect an overly aggressive ignition map might be to blame. As well, it's got some spots in the fuelling that are still rough around the edges, and I don't think I've got the patience to do anything but DRIVE the damned thing (who wants to fiddle around with the laptop when I could be enjoying the car?).
As a result, I think I'd like to buy some dyno time with a tuner that's familiar with both the type IV and the MegaSquirt... does anyone have any recommendations? For reference, I'm tuned for ~14.5 at cruise and about 36 degrees of advance at 3100 RPM cruise on the highway. I'm seeing head temps settling around 360 with up to 385 (IMG:style_emoticons/default/unsure.gif) on long uphill sections, and oil temps of about 230. Around town temps hang out at about 345 and 225. Thanks in advance for the advice! This forum is a really great resource. |
| Jake Raby |
Feb 23 2010, 03:29 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE Cool - I've got an appointment with Dean @ Raby's shop set up . We'll see you then. QUOTE I'm still going to tweak the map so I know it's safe for the drive up there >> Have the engine tuned as well as possible. Have all engine issues worked out, to include oil leaks and fuel leaks. We don't test engines with leaks as they are a fire hazard. To best use your time on the dyno have the tuning done as far as possible and ensure the engine and tranny are healthy and won't cost time and money. QUOTE (holy crap is it far out of town!), Yep, on purpose.. We function in our own world where it is quiet and we don't get bothered. I took these pictures out my office window yesterday morning... QUOTE so feel free to keep the tips coming. Sounds like I need to back the cruise and power timing out quite a bit. I haven't hit it with a light yet, but the PO wasn't a total 'tard so it's probably close enough for my work. You'll see what works and what doesn't work when tuning for power and efficiency on my dyno. Most engines leave my dyno with 20HP more than they came here with, hopefully you'll be another one of those. This post has been edited by Jake Raby: Feb 23 2010, 03:47 PM |
thenewwazoo ATL area type IV megasquirt tuners? Feb 20 2010, 09:37 PM
kg6dxn Are you running a MAP sensor? it sounds like you m... Feb 20 2010, 10:07 PM
thenewwazoo
Are you running a MAP sensor? it sounds like you ... Feb 20 2010, 10:10 PM
brer hey, would be at all interested in sharing some 9... Feb 20 2010, 10:47 PM
underthetire
hey, would be at all interested in sharing some ... Feb 20 2010, 10:52 PM
904svo I live in wodstock am I still trying to get my Meg... Feb 21 2010, 08:31 AM
McMark I'm a huge proponent of crank triggering for M... Feb 21 2010, 10:37 AM
underthetire
I'm a huge proponent of crank triggering for ... Feb 21 2010, 10:45 AM
thenewwazoo That may be, but you're also selling something... Feb 21 2010, 10:40 AM
McMark :agree: for fuel only, you can get away with coil ... Feb 21 2010, 11:48 AM
underthetire
:agree: for fuel only, you can get away with coil... Feb 21 2010, 12:08 PM
thenewwazoo
... especially at low RPM and idle.
Okay, well,... Feb 21 2010, 05:22 PM
DBCooper
:agree: for fuel only, you can get away with coil... Feb 21 2010, 05:32 PM
904svo I'm running Megasquirt with a 36-1 tooth wheel... Feb 21 2010, 04:10 PM
underthetire
I'm running Megasquirt with a 36-1 tooth whee... Feb 21 2010, 04:35 PM
904svo
I'm running Megasquirt with a 36-1 tooth whe... Feb 21 2010, 05:20 PM
underthetire
[quote name='underthetire' post='1276811' date='F... Feb 21 2010, 05:24 PM
John Jentz
I'm running Megasquirt with a 36-1 tooth whe... Feb 21 2010, 05:42 PM
BIGKAT_83 Should be no trouble finding someone in Atlanta to... Feb 21 2010, 05:46 PM
904svo
My (fairly new-to-me) megasquirted '74 2L is ... Feb 21 2010, 08:58 PM
thenewwazoo
Type 4 like to run about 13:1 to stay cool at tho... Feb 21 2010, 09:25 PM
kg6dxn try this link
http://914megasquirt.ning.com/ Feb 21 2010, 10:09 PM
brer
try this link
y... Feb 22 2010, 12:37 PM
Jake Raby I'm no fan of MS, but I'd be happy to assi... Feb 21 2010, 10:28 PM
thenewwazoo
I'm no fan of MS, but I'd be happy to ass... Feb 22 2010, 01:01 PM
Al Meredith I think in your first post you said you were runni... Feb 22 2010, 12:52 PM
thenewwazoo
I think in your first post you said you were runn... Feb 22 2010, 01:05 PM
toon1
My (fairly new-to-me) megasquirted '74 2L is ... Feb 22 2010, 06:41 PM
Jake Raby I agree.. Over-advancing is pretty easy to do, esp... Feb 23 2010, 02:22 PM
underthetire While I agree with both of you, 36 is too much, it... Feb 23 2010, 02:35 PM
thenewwazoo Cool - I've got an appointment with Dean @ Rab... Feb 23 2010, 02:56 PM
904svo Jake, are on lookers allowed to watch? Feb 23 2010, 04:01 PM
Jake Raby
[u][size... Feb 23 2010, 04:16 PM
thenewwazoo Man, that was great! Jake let me invite all my... Mar 17 2010, 02:07 PM
Jake Raby Glad to see the car is better than it was when you... Mar 17 2010, 03:25 PM
JamesM Did the tuning help with the head temps? Also, wh... Mar 17 2010, 07:21 PM
thenewwazoo
Did the tuning help with the head temps? Also, w... Mar 17 2010, 08:57 PM
904svo If you are using a FI cam, you may have to rebuild... Mar 17 2010, 08:05 PM
thenewwazoo
If you are using a FI cam, you may have to rebuil... Mar 17 2010, 08:58 PM
904svo
If you are using a FI cam, you may have to rebui... Mar 17 2010, 09:22 PM
thenewwazoo
The tables are 12X12 or 8x8. If you don't use... Mar 17 2010, 09:26 PM
904svo
[quote name='904svo' post='1288347' date='Mar 17 ... Mar 17 2010, 09:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:18 AM |
