| hwgunner |
Feb 24 2010, 03:17 PM
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
So i have been thinking about this for a long time and I finally took the plunge. this is what i came up with.
Introducing the new GPRBar for Porsche 911’s and 914’s. A German Parts & Restoration exclusive, designed by Tarett Engineering, the NEW GPRBar is 19.4mm equivalent and is a modular design that can be used as a complete system or can be purchased separately as the BarKit (the bar and bearing blocks) to install with your stock sway bar arms and drop links or the ArmKit (the adjustable sway bar arms and adjustable drop links) to install with your stock through body sway bar. These light weight hollow sway bars are half the weight of a solid bar with the same stiffness. The bar itself is made from aircraft-quality 4130 chrome moly steel, heat treated and zinc plated for strength and durability. The adjustable arms and adjustable drop links are CNC machined from aircraft-quality 6061-T6 Aluminum for its strength and durability. Correctly sized, precision, Teflon-lined rod-ends mean smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends. Thermoplastic bushings impregnated with Teflon and reinforced with Kevlar provide smooth operation, long life, and high resistance to deflecting under heavy loading. All necessary hardware is provided in zinc plated metric class 8.8. GPRBar $475.00 BarKit $250.00 ArmKit $250.00 Also available for the Porsche 911 is the rear GPRBar. Same great materials as above with a 19.4mm equivalent bar. This is a complete sway bar set up. (911 Rear GPRBar $475) |
| aircooledtechguy |
Feb 24 2010, 04:13 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Looks like a really nice product (as with all Tarett Engineering products). One question; is the difference between this bar assembly and the ones available on the Tarett site that yours is equivalent to a 19mm bar and the Tarett sites bar is equivalent to a 22mm?? thanks. Again, NICE product!! I am planning a front bar upgrade in the future and it's nice to have such high quality choices out there. (IMG:style_emoticons/default/beerchug.gif)
| hwgunner |
Feb 24 2010, 04:30 PM
Looks like a really nice product (as with all Tarett Engineering products). One question; is the difference between this bar assembly and the ones available on the Tarett site that yours is equivalent to a 19mm bar and the Tarett sites bar is equivalent to a 22mm?? thanks. Again, NICE product!! I am planning a front bar upgrade in the future and it's nice to have such high quality choices out there. (IMG:style_emoticons/default/beerchug.gif) Yes there are 2 major difference between the two bars. first, the Tarett bar is 25.4mm diameter with the efective rate of a 22mm solid bar. The GPRBar has 22.22mm diameter with the efective rate of a 19mm solid bar. The other difference is that the GPRBar is modular. You can buy just the bar and bearing blocks and use your stock Porsche sway bar arms and drop links or you can get the Arm Kit and use your stock Porsche sway bar. The Tarett sway bar end is much larger than mine and will not tighten down over a stock sway bar end. |
hwgunner New GPRBar SWAY BAR Kinda Cool, I Think Feb 24 2010, 03:17 PM
jcambo7 I want one of these! :driving: Feb 24 2010, 03:41 PM
markb Operators are standing by.......... :D Feb 24 2010, 03:52 PM
jcambo7
Yeah. I ... Feb 24 2010, 04:00 PM
hwgunner
Yeah. I... Feb 24 2010, 04:08 PM
jcambo7
[quote name='jcambo7' post='1278441' date='Feb 24... Feb 24 2010, 04:16 PM
A suggestion ... Feb 24 2010, 04:14 PM
hwgunner
A suggestion... Feb 24 2010, 05:09 PM
I will see what i can do about this. Great idea.... Feb 24 2010, 05:15 PM
jcambo7 :agree: This would definitely help out a lot that... Feb 24 2010, 07:51 PM
McMark :headbanger: Feb 24 2010, 08:47 PM
dr914@autoatlanta.com Dave was always quite the innovator and it looks l... Feb 24 2010, 09:01 PM
hwgunner
Dave was always quite the innovator and it looks ... Feb 24 2010, 11:23 PM
Eric_Shea I heard about this from Ira... great idea.
Andy... Feb 24 2010, 09:01 PM
6freak splines on the end of the sway bar it self would b... Feb 25 2010, 11:27 AM
hwgunner
splines on the end of the sway bar it self would ... Feb 25 2010, 01:53 PM
Dave_Darling Aaahndy, you can make a lot of markings with a ... Feb 25 2010, 02:50 PM
Aaahndy, you can make a lot of markings with a ... Feb 25 2010, 02:54 PM
rdauenhauer Jonathan so the round retaining elements are Beari... Feb 25 2010, 06:11 PM
hwgunner
Jonathan so the round retaining elements are Bear... Feb 26 2010, 11:36 AM
siverson > I have a very early Tarett bar and otherwise ... Feb 25 2010, 08:23 PM
Let me know if I'm wrong though...
You are co... Feb 25 2010, 09:43 PM
Chris Hamilton So the $475 GPR bar is just the bar and bushi... Feb 25 2010, 10:00 PM
hwgunner
So the $475 GPR bar is just the bar and bush... Feb 26 2010, 09:39 AM
sww914 I have one of these at my shop right now and it is... Feb 25 2010, 10:02 PM
sean_v8_914 markings, YES! we have a Tarret bar on the 10j... Feb 26 2010, 08:56 AM
Phoenix 914-6GT Nice Jonathan :headbanger:
Still have my big Tar... Feb 26 2010, 11:27 AM
mtn flyr Are these in stock at this time? Feb 26 2010, 01:59 PM
hwgunner
Yes they are i... Feb 26 2010, 02:01 PM
BigD9146gt New GPRBar SWAY BAR Kinda Cool, I Think
WAY TO G... Feb 26 2010, 02:14 PM
mtn flyr I'll be in touch soon, and here is a :bump: ... Feb 27 2010, 08:35 PM
campbellcj If somebody made a REAR 914 swaybar with better qu... Feb 28 2010, 10:58 AM
markb :bump: I spent all day putting together the kits f... Mar 3 2010, 07:15 PM
nsr-jamie Hi, I know this is an older thread, I am very inte... Nov 6 2010, 02:41 AM
tradisrad I got my GPRBar in the mail today and it looks gre... Nov 8 2010, 04:30 PM
hwgunner
I got my GPRBar in the mail today and it looks gr... Nov 8 2010, 05:33 PM
RobW I picked the one up that was in the classifieds...... Nov 8 2010, 05:56 PM
tradisrad
I picked the one up that was in the classifieds..... Nov 8 2010, 05:59 PM
RobW
I picked the one up that was in the classifieds.... Nov 8 2010, 06:19 PM
NC_Colfax Looks like a very well made product Nov 8 2010, 05:57 PM
Eric_Shea Sounds like you're doing the right thing. :tro... Nov 8 2010, 06:01 PM
SirAndy If you get the arms with it, set them full soft an... Nov 8 2010, 06:10 PM
tradisrad The New GPRBar is installed. I took it for a short... Nov 9 2010, 08:55 AM
DanT with the longer arm set at full soft, you are prob... Nov 9 2010, 09:17 AM
tradisrad
with the longer arm set at full soft, you are pro... Nov 9 2010, 09:51 AM
SirAndy So, how do I know what setting of the bar will giv... Nov 9 2010, 01:26 PM
Racer Chris
Start with the bar set to full soft and tighten u... Nov 9 2010, 08:50 PM
SirAndy I think you've got that backwards Andy.
soft f... Nov 9 2010, 09:58 PM
Eric_Shea
Just for the fun of it... I'm going to :agr... Nov 9 2010, 09:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 02:03 PM |
