OMG! Carb manifolds are crap..., Straight out of the box |
McMark |
Feb 24 2010, 06:33 PM
No real surprise here. The manifolds for carbs are pretty crappy. I just spent WAY TOO LONG truing up a set with sandpaper on glass. I snapped a couple of pics to show just how not flat these things are. I would expect a huge vacuum leak if I had left these guys alone.
The area in the circle shows what hasn't been touched yet by the sandpaper. This is after a LOT of sanding. And it took a LOT more to get it completely out. This is a cheap, and relatively quick project that any carb owner can do with the engine in the car. All you need is a piece of thick glass, which most any house glass shop should be able to cut for you and round the edges, for cheap. Some sandpaper and tape and a sure, steady hand. Hold the manifolds flat against the glass and use long, even, slow strokes. You can also use a sharpie to check your work as you get closer to finishing. Draw on the surface, take a couple strokes, then see how much sharpie has been removed. Attached image(s) |
URY914 |
Feb 24 2010, 08:22 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,968 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I fitted a steel spacer to pull the base down to the head so it will seal. Have a look...
Ferg |
Feb 24 2010, 08:34 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I fitted a steel spacer to pull the base down to the head so it will seal. Have a look... That spacer looks heavy (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:31 PM |
