OMG! Carb manifolds are crap..., Straight out of the box |
McMark |
Feb 24 2010, 06:33 PM
No real surprise here. The manifolds for carbs are pretty crappy. I just spent WAY TOO LONG truing up a set with sandpaper on glass. I snapped a couple of pics to show just how not flat these things are. I would expect a huge vacuum leak if I had left these guys alone.
The area in the circle shows what hasn't been touched yet by the sandpaper. This is after a LOT of sanding. And it took a LOT more to get it completely out. This is a cheap, and relatively quick project that any carb owner can do with the engine in the car. All you need is a piece of thick glass, which most any house glass shop should be able to cut for you and round the edges, for cheap. Some sandpaper and tape and a sure, steady hand. Hold the manifolds flat against the glass and use long, even, slow strokes. You can also use a sharpie to check your work as you get closer to finishing. Draw on the surface, take a couple strokes, then see how much sharpie has been removed. Attached image(s) |
'73-914kid |
Feb 25 2010, 08:18 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Huh, my CB Performance manfiolds were actually pretty nice. I had to do almost no final filing to get them perfectly flat...
I'm surprise that the factory will let those go out that uneven. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:12 PM |
