> Transmission, Clutch won't engage
jsaum
post Mar 7 2010, 02:03 AM
I seem to back to square one with my car. Twelve years ago when I got the car the clutch wouldn't engage. I pulled the motor and transmission found what the hell hole was and am just now getting it back together.
Here's where I'm at I have replaced the clutch tube using a thicker tube from McMaster Carr, I have 1 1/2 of tube sticking out at the fire wall, it was almost flush before! I had the fly wheel surfaced, new disk and pressure plate, throw out bearing and replace the pivot cup. When the engine and transmission are assembled there's maybe 1/4 inch travel for the release lever before it stops on the housing. The pivot ball has one washer behind it which seems normal, I have read that you can add washers to space it out for better travel how many should I try to add? What is the normal travel on the release lever? The lever doesn't look bent I have a second tranny and lever and they both look the same. The new pressure plate and clutch are Sachs type M215 i believe this is correct. You can get an idea from the pictures what the cable looks like it is fully adjusted. Has anyone had this same issue?
Thanks for the help!
Jsaum
Chris Pincetich
post Mar 7 2010, 10:24 AM
B-)
I'm headed to the garage to put all this back together too, and might have some advice, but when you say the clutch "won't engage" this is because
1) you can't shift gears from the shift lever while behind the steering wheel?
2) you can't select a different gear manually moving the the small lever sitcking out the driver's side of the transmission?
3) Pushing the clutch pedal does not disengage the driveline?
If it is 1-2, might be problems with your shift forks or transaxle internals. If it is really 3, then you are asking the right questions....
If the flywheel has been worked on a lot it may be out of spec....
If you manually push the release lever, and the clutch works, your cable needs more adjustment
Good luck
- Lo-Fi Version Time is now: 16th June 2024 - 09:34 PM
