Transmission, Clutch won't engage |
jsaum |
Mar 7 2010, 02:03 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I seem to back to square one with my car. Twelve years ago when I got the car the clutch wouldn't engage. I pulled the motor and transmission found what the hell hole was and am just now getting it back together.
Here's where I'm at I have replaced the clutch tube using a thicker tube from McMaster Carr, I have 1 1/2 of tube sticking out at the fire wall, it was almost flush before! I had the fly wheel surfaced, new disk and pressure plate, throw out bearing and replace the pivot cup. When the engine and transmission are assembled there's maybe 1/4 inch travel for the release lever before it stops on the housing. The pivot ball has one washer behind it which seems normal, I have read that you can add washers to space it out for better travel how many should I try to add? What is the normal travel on the release lever? The lever doesn't look bent I have a second tranny and lever and they both look the same. The new pressure plate and clutch are Sachs type M215 i believe this is correct. You can get an idea from the pictures what the cable looks like it is fully adjusted. Has anyone had this same issue? Thanks for the help! Jsaum Attached image(s) |
jsaum |
Mar 7 2010, 01:04 PM
Just measured the distance on mine it is 10 mm from the ring gear to the pp mounting surface I think this is the problem! The other flywheel I have looks better the distance is 6.7mm so it looks like the PP will sit down further allowing the diaphram springs to contact the throwout bearing and pivot arm correctly. Also Underthetire thanks for pointing out the dowel pins I'll have to get some are they anything special or can I use ones from the local hardware store?
Thanks, Jsaum |
Lo-Fi Version | Time is now: 16th June 2024 - 06:47 PM |
