> Tubular Space Frame?, How would you do it?
plymouth37
post Mar 8 2010, 07:57 PM
So I have been playing with the idea of adding a couple more tubes to the back of the Anklebiter. If you were to replace the back half of a 914 with tubes where would you put them? Here is a rendering of the original cage (red), drivetrain (Grey), and points that need to be tied in (green).
What would you do?
underthetire
post Mar 8 2010, 08:18 PM
Dam. Just cut the body off the pan and build a whole tube frame (IMG:style_emoticons/default/biggrin.gif)
plymouth37   Tubular Space Frame?   Mar 8 2010, 07:57 PM
plymouth37   Here is my first draft, any thoughts?   Mar 8 2010, 07:57 PM
SirAndy   any thoughts? Overkill? :confused:   Mar 8 2010, 08:24 PM
plymouth37   any thoughts? Overkill? :confused: This is the...   Mar 8 2010, 08:27 PM
SirAndy   I want it to be able to handle at least 500hp bu...   Mar 8 2010, 08:34 PM
plymouth37   RE: Tubular Space Frame?   Mar 8 2010, 08:11 PM
underthetire   Dam. Just cut the body off the pan and build a who...   Mar 8 2010, 08:18 PM
plymouth37   I would like to keep the passenger compartment int...   Mar 8 2010, 08:23 PM
URY914   RE: Tubular Space Frame?   Mar 8 2010, 08:28 PM
URY914   RE: Tubular Space Frame?   Mar 8 2010, 08:29 PM
SirAndy   Ury, that stock starter looks heavy ... :shades2:...   Mar 8 2010, 08:32 PM
plymouth37   I was thinking of yours when I was working on this...   Mar 8 2010, 08:32 PM
BigD9146gt   I was thinking of yours when I was working on thi...   Mar 9 2010, 03:30 AM
plymouth37   The plan would be to eliminate all sheet metal beh...   Mar 8 2010, 08:37 PM
SirAndy   More examples, some better, some not so much (IMHO...   Mar 8 2010, 08:42 PM
jd74914   I like the design you posted. You really do need m...   Mar 8 2010, 08:47 PM
Crazyhippy   The tube from the long too the motor mount wont be...   Mar 8 2010, 08:54 PM
plymouth37   Tube wall thickness is another factor, I like the ...   Mar 8 2010, 08:55 PM
Jeff Hail   Cost no object I would go the route Hari Matsuda w...   Mar 9 2010, 02:14 AM
Jeff Hail   Hari's latest configuration was this.   Mar 9 2010, 02:19 AM
URY914   500hp puts you in a different crowd than my car. H...   Mar 9 2010, 07:44 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:45 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:47 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:53 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:55 AM
URY914   I have more pictures but I'd have to spend the...   Mar 9 2010, 08:03 AM
rick 918-S   A Celette would be slick for a tube chassis. You...   Mar 9 2010, 08:08 AM
Brett W   The 914 chassis is far from good. I think the fac...   Mar 9 2010, 09:52 AM
rick 918-S   The 914 chassis is far from good. I think the fa...   Mar 9 2010, 11:06 AM
FourBlades   :agree: :agree: :agree: Just build more stu...   Mar 9 2010, 11:35 AM
plymouth37   Thanks for the input guys, lots of great pics. I a...   Mar 9 2010, 10:41 AM
Rand   Top of shock tower (bridging the hidden gap betwee...   Mar 9 2010, 11:25 AM
URY914   You build it and some will like it, some won't...   Mar 9 2010, 11:45 AM
d914   some one needs to design a full tube frame car...t...   Mar 9 2010, 11:47 AM
URY914   some one needs to design a full tube frame car......   Mar 9 2010, 12:50 PM
plymouth37   You build it and some will like it, some won...   Mar 9 2010, 11:49 AM
J P Stein   Were I going to the trouble of building a tube fra...   Mar 9 2010, 01:42 PM
SirAndy   So I have been playing with the idea of adding a ...   Mar 9 2010, 02:15 PM
plymouth37   So I have been playing with the idea of adding a...   Mar 9 2010, 10:10 PM
jd74914   Are you still in school? If you are you should gra...   Mar 10 2010, 07:42 AM
plymouth37   Are you still in school? If you are you should gr...   Mar 10 2010, 02:12 PM
jd74914   That is actually a really good idea, the formula ...   Mar 11 2010, 09:34 AM
WRX914   Ohhh to have the time to entertain these things...   Mar 11 2010, 09:17 AM
plymouth37   Ohhh to have the time to entertain these things...   Mar 11 2010, 09:58 AM
YksKrad   I'm not too good with this kind of stuff, but ...   Mar 14 2010, 01:47 AM
Rand   My Qs are in blue. You already have the crosses to...   Mar 14 2010, 10:46 PM
sixnotfour   :idea:   Mar 14 2010, 10:54 PM
Dave_Darling   IIRC, the "Birdcage" Maser was a very ea...   Mar 14 2010, 11:54 PM
sixnotfour   :poke: 200 tubes   Mar 15 2010, 02:06 AM
jd74914   :poke: 200 tubes Eh, those are easy joints. The...   Mar 15 2010, 07:50 AM
sean_v8_914   chop chop!   Mar 15 2010, 04:00 PM
sean_v8_914   how much wire do ya think they used here?   Mar 15 2010, 04:01 PM
- Lo-Fi Version Time is now: 8th January 2026 - 05:16 PM
