| plymouth37 |
Mar 8 2010, 07:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
So I have been playing with the idea of adding a couple more tubes to the back of the Anklebiter. If you were to replace the back half of a 914 with tubes where would you put them? Here is a rendering of the original cage (red), drivetrain (Grey), and points that need to be tied in (green).
What would you do? Attached image(s)
| Brett W |
Mar 9 2010, 09:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None
The 914 chassis is far from good. I think the factory chassis stiffness is on the order of 2500lbs/deg. That is really weak. The factory chassis is a noodle.
As for the tube chassis. I would use 1.5x.045 and 1.5x.065 tubing. No need to get really big. Sheridan's car is probably the best engineered solution. It was done by a professional race car engineer. If you are going to do it I would toss the factory rear suspension and come up with something different. Mount the engine, tranny and suspension to an independent cradle. Then you could fix the 914 problems. The problem isn't flex in the rear of the chassis though. It flexes in the middle. So you will not gain much buy changing the rear. Plus the rear is pretty light because it is all sheetmetal. |
| rick 918-S |
Mar 9 2010, 11:06 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,165 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
The 914 chassis is far from good. I think the factory chassis stiffness is on the order of 2500lbs/deg. That is really weak. The factory chassis is a noodle. As for the tube chassis. I would use 1.5x.045 and 1.5x.065 tubing. No need to get really big. Sheridan's car is probably the best engineered solution. It was done by a professional race car engineer. If you are going to do it I would toss the factory rear suspension and come up with something different. Mount the engine, tranny and suspension to an independent cradle. Then you could fix the 914 problems. The problem isn't flex in the rear of the chassis though. It flexes in the middle. So you will not gain much buy changing the rear. Plus the rear is pretty light because it is all sheetmetal. I agree the center of the chassis is where the 914 is lacking. I don't agree the entire chassis is bad. The rear and front sections are very nicely built for a street car. Stiffening where the shock towers crack in the engine bay side and a support for the inside suspension ear are always a good idea. There is alot of overkill being built into 914's. I think it's just because guys like to build stuff. BTW: I have zero chassis stiffening in my car. Yep. Zero. The rear of the chassis is just fine. Infact I removed the internal brace (boxed structure) just above the rear engine tin that crosses from tower to tower. I have in excess of 350 hp now with a very heavy engine. About equal to the weight of a big block chevy. If I Ax'ed on a regular basis or raced, I would rethink this. But for a occasional thrashing like Monument National Park or a trip to and from Mount Wilson these cars rock! It would be interesting to gauge what is happening to the chassis ahead of the rear firewall though... (IMG:style_emoticons/default/unsure.gif) Dana, Build it like you want it. We love your work. (IMG:style_emoticons/default/popcorn[1].gif) |
plymouth37 Tubular Space Frame? Mar 8 2010, 07:57 PM
plymouth37 Here is my first draft, any thoughts? Mar 8 2010, 07:57 PM
any thoughts?
Overkill? :confused: Mar 8 2010, 08:24 PM
plymouth37
any thoughts?
This is the... Mar 8 2010, 08:27 PM
I want it to be able to handle at least 500hp bu... Mar 8 2010, 08:34 PM
plymouth37 RE: Tubular Space Frame? Mar 8 2010, 08:11 PM
underthetire Dam. Just cut the body off the pan and build a who... Mar 8 2010, 08:18 PM
plymouth37 I would like to keep the passenger compartment int... Mar 8 2010, 08:23 PM
URY914 RE: Tubular Space Frame? Mar 8 2010, 08:28 PM
URY914 RE: Tubular Space Frame? Mar 8 2010, 08:29 PM
SirAndy Ury, that stock starter looks heavy ... :shades2:... Mar 8 2010, 08:32 PM
plymouth37 I was thinking of yours when I was working on this... Mar 8 2010, 08:32 PM
BigD9146gt
I was thinking of yours when I was working on thi... Mar 9 2010, 03:30 AM
plymouth37 The plan would be to eliminate all sheet metal beh... Mar 8 2010, 08:37 PM
SirAndy More examples, some better, some not so much (IMHO... Mar 8 2010, 08:42 PM
jd74914 I like the design you posted. You really do need m... Mar 8 2010, 08:47 PM
Crazyhippy The tube from the long too the motor mount wont be... Mar 8 2010, 08:54 PM
plymouth37 Tube wall thickness is another factor, I like the ... Mar 8 2010, 08:55 PM
Jeff Hail Cost no object I would go the route Hari Matsuda w... Mar 9 2010, 02:14 AM
Jeff Hail Hari's latest configuration was this. Mar 9 2010, 02:19 AM
URY914 500hp puts you in a different crowd than my car. H... Mar 9 2010, 07:44 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:45 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:47 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:53 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:55 AM
URY914 I have more pictures but I'd have to spend the... Mar 9 2010, 08:03 AM
rick 918-S A Celette would be slick for a tube chassis. You... Mar 9 2010, 08:08 AM
FourBlades
:agree: :agree: :agree:
Just build more stu... Mar 9 2010, 11:35 AM
plymouth37 Thanks for the input guys, lots of great pics. I a... Mar 9 2010, 10:41 AM
Rand Top of shock tower (bridging the hidden gap betwee... Mar 9 2010, 11:25 AM
URY914 You build it and some will like it, some won't... Mar 9 2010, 11:45 AM
d914 some one needs to design a full tube frame car...t... Mar 9 2010, 11:47 AM
URY914
some one needs to design a full tube frame car...... Mar 9 2010, 12:50 PM
plymouth37
You build it and some will like it, some won... Mar 9 2010, 11:49 AM
J P Stein Were I going to the trouble of building a tube fra... Mar 9 2010, 01:42 PM
So I have been playing with the idea of adding a ... Mar 9 2010, 02:15 PM
plymouth37
So I have been playing with the idea of adding a... Mar 9 2010, 10:10 PM
jd74914 Are you still in school? If you are you should gra... Mar 10 2010, 07:42 AM
plymouth37
Are you still in school? If you are you should gr... Mar 10 2010, 02:12 PM
jd74914
That is actually a really good idea, the formula ... Mar 11 2010, 09:34 AM
WRX914 Ohhh to have the time to entertain these things... Mar 11 2010, 09:17 AM
plymouth37
Ohhh to have the time to entertain these things... Mar 11 2010, 09:58 AM
YksKrad I'm not too good with this kind of stuff, but ... Mar 14 2010, 01:47 AM
Rand My Qs are in blue. You already have the crosses to... Mar 14 2010, 10:46 PM
sixnotfour :idea: Mar 14 2010, 10:54 PM
Dave_Darling IIRC, the "Birdcage" Maser was a very ea... Mar 14 2010, 11:54 PM
sixnotfour :poke: 200 tubes Mar 15 2010, 02:06 AM
jd74914
:poke: 200 tubes
Eh, those are easy joints. The... Mar 15 2010, 07:50 AM
sean_v8_914 chop chop! Mar 15 2010, 04:00 PM
sean_v8_914 how much wire do ya think they used here? Mar 15 2010, 04:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th January 2026 - 05:14 PM |
