> Transmission Soda, Bead or Walnut Shell Blasting
kconway
post Mar 9 2010, 06:43 PM
I was wondering if it would be safe to soda, bead or walnut shell blast my transmission whole if I taped off the vent and perhaps the part lines in the case as to not hit the seals? I have a newly rebuilt transmission I'd like to clean up without tearing back down again.
Kev
kconway
post Mar 9 2010, 08:10 PM
Truth be told, the DACO (Dumb Ass Current Owner) that'd be me rattle canned it. Instead of waiting for it to flake and drip off on my garage floor I'd like to undue the damage before it goes back into my car. I did use high temp paint... (IMG:style_emoticons/default/blink.gif)
Whadda Bonehead!
Tom_T
post Mar 9 2010, 08:48 PM
TMI....
QUOTE(kconway @ Mar 9 2010, 06:10 PM) *
Whadda Bonehead!
Try Acetone - apply - wait a few to soften paint - tooth brush in crevices & scrub brush - repeat as necessary!
DAPO &/or DACO did that with paint on my used Fuchs 2L (former), & on body plates & labels on past repaints (both) on mine! (IMG:style_emoticons/default/biggrin.gif)
kconway   Transmission Soda, Bead or Walnut Shell Blasting   Mar 9 2010, 06:43 PM
McMark   Soda would be the only thing I would even consider...   Mar 9 2010, 06:47 PM
Vacca Rabite   no.   Mar 9 2010, 06:52 PM
Tom_T   Kev - Maybe just some POR Marine Clean away from ...   Mar 9 2010, 07:03 PM
bandjoey   Harbor Freight sells a spray bottle that attaches ...   Mar 9 2010, 07:11 PM
kconway   Truth be told, the DACO (Dumb Ass Current Owner) t...   Mar 9 2010, 08:10 PM
Tom_T   Truth be told, the DACO (Dumb Ass Current Owner) ...   Mar 9 2010, 08:48 PM
Vacca Rabite   Truth be told, the DACO (Dumb Ass Current Owner) ...   Mar 10 2010, 07:38 AM
McMark   Brake cleaner usually takes off rattle can paint R...   Mar 9 2010, 09:52 PM
bigkensteele   While I understand the apprehension to condone ful...   Mar 9 2010, 11:24 PM
McMark   I agree that soda is probably safe. I won't b...   Mar 9 2010, 11:30 PM
Mark Henry   I'd just stick it in and the 914 automatic cor...   Mar 10 2010, 02:34 AM
ME733   ....Use as mcmark suggested- brake cleaner- first,...   Mar 10 2010, 07:36 AM
sean_v8_914   I put my complete trans in my jet wash cabinet. st...   Mar 10 2010, 08:23 AM
sean_v8_914   soda is an abrasive. does it disolve in oil?   Mar 10 2010, 08:24 AM
tdgray   Back the cart up boyz... some of you are saying th...   Mar 10 2010, 09:10 AM
McMark   I wouldn't blast assembled carbs and then thro...   Mar 10 2010, 09:18 AM
Vacca Rabite   When I blasted my carbs, the were out of the car a...   Mar 10 2010, 10:08 AM
tdgray   When I blasted my carbs, the were out of the car ...   Mar 10 2010, 12:19 PM
Eric_Shea   I've personally seen walnut. It gives "p...   Mar 10 2010, 10:15 AM
sean_v8_914   YES!!! even oven cleaner will eat it i...   Mar 10 2010, 11:19 AM
kconway   Are the gaskets between case part lines vulnerable...   Mar 10 2010, 12:43 PM
Tom_T   After blasting or cleaning - you may want to try a...   Mar 10 2010, 01:56 PM
kwales   The circular logic that goes on here sometimes is ...   Mar 10 2010, 05:17 PM
kconway   I think the bottom line to this discussion is how ...   Mar 10 2010, 06:20 PM
Tom_T   I think the bottom line to this discussion is how...   Mar 10 2010, 10:19 PM
kwales   It's pretty simple to explain. Start yer co...   Mar 10 2010, 06:32 PM
kconway   It's pretty simple to explain. Start yer c...   Mar 10 2010, 07:03 PM
kwales   I'm just curious why you are even asking us? ...   Mar 10 2010, 07:22 PM
kconway   I'm just curious why you are even asking us? ...   Mar 10 2010, 08:56 PM
Dr Evil   Place your bets, place your bets :rolleyes: You h...   Mar 10 2010, 08:30 PM
McMark   :confused: Blast your transmission already. ...   Mar 10 2010, 10:36 PM
r_towle   NO! Forget the media you are using for a secon...   Mar 10 2010, 10:43 PM
kconway   NO! Forget the media you are using for a seco...   Mar 10 2010, 11:19 PM
r_towle   Axle shaft oil seals will let debris in. Rear spee...   Mar 10 2010, 11:46 PM
Eric_Shea   I don't think Kevin deserves all of the ...   Mar 11 2010, 08:20 AM
kwales   Kevin, Maybe I wasn't clear and you took it ...   Mar 11 2010, 09:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:49 AM
