| kconway |
Mar 9 2010, 06:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I was wondering if it would be safe to soda, bead or walnut shell blast my transmission whole if I taped off the vent and perhaps the part lines in the case as to not hit the seals? I have a newly rebuilt transmission I'd like to clean up without tearing back down again.
Kev |
| ME733 |
Mar 10 2010, 07:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
....Use as mcmark suggested- brake cleaner- first,... then finish up with pump spray bottle of MAG WHEEL cleaner., watch it foam off the last of the oil and put a shine/original look back to the tranny....got to be careful tho-certain mag wheel cleaners will DARKEN if left on too long.....start at 5 minutes and judge results., flush with lots of water when done...........................M.M.
kconway Transmission Soda, Bead or Walnut Shell Blasting Mar 9 2010, 06:43 PM
McMark Soda would be the only thing I would even consider... Mar 9 2010, 06:47 PM
Vacca Rabite no. Mar 9 2010, 06:52 PM
Tom_T Kev -
Maybe just some POR Marine Clean away from ... Mar 9 2010, 07:03 PM
bandjoey Harbor Freight sells a spray bottle that attaches ... Mar 9 2010, 07:11 PM
kconway Truth be told, the DACO (Dumb Ass Current Owner) t... Mar 9 2010, 08:10 PM
Tom_T
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 9 2010, 08:48 PM
Vacca Rabite
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 10 2010, 07:38 AM
McMark Brake cleaner usually takes off rattle can paint R... Mar 9 2010, 09:52 PM
bigkensteele While I understand the apprehension to condone ful... Mar 9 2010, 11:24 PM
McMark I agree that soda is probably safe. I won't b... Mar 9 2010, 11:30 PM
Mark Henry I'd just stick it in and the 914 automatic cor... Mar 10 2010, 02:34 AM
sean_v8_914 I put my complete trans in my jet wash cabinet. st... Mar 10 2010, 08:23 AM
sean_v8_914 soda is an abrasive. does it disolve in oil? Mar 10 2010, 08:24 AM
tdgray Back the cart up boyz... some of you are saying th... Mar 10 2010, 09:10 AM
McMark I wouldn't blast assembled carbs and then thro... Mar 10 2010, 09:18 AM
Vacca Rabite When I blasted my carbs, the were out of the car a... Mar 10 2010, 10:08 AM
tdgray
When I blasted my carbs, the were out of the car ... Mar 10 2010, 12:19 PM
Eric_Shea I've personally seen walnut. It gives "p... Mar 10 2010, 10:15 AM
sean_v8_914 YES!!! even oven cleaner will eat it i... Mar 10 2010, 11:19 AM
kconway Are the gaskets between case part lines vulnerable... Mar 10 2010, 12:43 PM
Tom_T After blasting or cleaning - you may want to try a... Mar 10 2010, 01:56 PM
kwales The circular logic that goes on here sometimes is ... Mar 10 2010, 05:17 PM
kconway I think the bottom line to this discussion is how ... Mar 10 2010, 06:20 PM
Tom_T
I think the bottom line to this discussion is how... Mar 10 2010, 10:19 PM
kwales It's pretty simple to explain.
Start yer co... Mar 10 2010, 06:32 PM
kconway
Start yer c... Mar 10 2010, 07:03 PM
kwales I'm just curious why you are even asking us?
... Mar 10 2010, 07:22 PM
kconway
... Mar 10 2010, 08:56 PM
Dr Evil Place your bets, place your bets :rolleyes:
You h... Mar 10 2010, 08:30 PM
McMark
:confused:
Blast your transmission already. ... Mar 10 2010, 10:36 PM
r_towle NO!
Forget the media you are using for a secon... Mar 10 2010, 10:43 PM
kconway
NO!
Forget the media you are using for a seco... Mar 10 2010, 11:19 PM
r_towle Axle shaft oil seals will let debris in.
Rear spee... Mar 10 2010, 11:46 PM
Eric_Shea I don't think Kevin deserves all of the ... Mar 11 2010, 08:20 AM
kwales Kevin,
Maybe I wasn't clear and you took it ... Mar 11 2010, 09:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:42 AM |
