> Transmission Soda, Bead or Walnut Shell Blasting
kconway
post Mar 9 2010, 06:43 PM
I was wondering if it would be safe to soda, bead or walnut shell blast my transmission whole if I taped off the vent and perhaps the part lines in the case as to not hit the seals? I have a newly rebuilt transmission I'd like to clean up without tearing back down again.
Kev
sean_v8_914
post Mar 10 2010, 11:19 AM
Chingon 601
YES!!! even oven cleaner will eat it if left on there more than 15-30 min. my parts wash has special sauce to prevent this but must be rinsed off ASAP. I spray them with wd 40 to keep fuz from growing
kconway   Transmission Soda, Bead or Walnut Shell Blasting   Mar 9 2010, 06:43 PM
McMark   Soda would be the only thing I would even consider...   Mar 9 2010, 06:47 PM
Vacca Rabite   no.   Mar 9 2010, 06:52 PM
Tom_T   Kev - Maybe just some POR Marine Clean away from ...   Mar 9 2010, 07:03 PM
bandjoey   Harbor Freight sells a spray bottle that attaches ...   Mar 9 2010, 07:11 PM
kconway   Truth be told, the DACO (Dumb Ass Current Owner) t...   Mar 9 2010, 08:10 PM
Tom_T   Truth be told, the DACO (Dumb Ass Current Owner) ...   Mar 9 2010, 08:48 PM
Vacca Rabite   Truth be told, the DACO (Dumb Ass Current Owner) ...   Mar 10 2010, 07:38 AM
McMark   Brake cleaner usually takes off rattle can paint R...   Mar 9 2010, 09:52 PM
bigkensteele   While I understand the apprehension to condone ful...   Mar 9 2010, 11:24 PM
McMark   I agree that soda is probably safe. I won't b...   Mar 9 2010, 11:30 PM
Mark Henry   I'd just stick it in and the 914 automatic cor...   Mar 10 2010, 02:34 AM
ME733   ....Use as mcmark suggested- brake cleaner- first,...   Mar 10 2010, 07:36 AM
sean_v8_914   I put my complete trans in my jet wash cabinet. st...   Mar 10 2010, 08:23 AM
sean_v8_914   soda is an abrasive. does it disolve in oil?   Mar 10 2010, 08:24 AM
tdgray   Back the cart up boyz... some of you are saying th...   Mar 10 2010, 09:10 AM
McMark   I wouldn't blast assembled carbs and then thro...   Mar 10 2010, 09:18 AM
Vacca Rabite   When I blasted my carbs, the were out of the car a...   Mar 10 2010, 10:08 AM
tdgray   When I blasted my carbs, the were out of the car ...   Mar 10 2010, 12:19 PM
Eric_Shea   I've personally seen walnut. It gives "p...   Mar 10 2010, 10:15 AM
sean_v8_914   YES!!! even oven cleaner will eat it i...   Mar 10 2010, 11:19 AM
kconway   Are the gaskets between case part lines vulnerable...   Mar 10 2010, 12:43 PM
Tom_T   After blasting or cleaning - you may want to try a...   Mar 10 2010, 01:56 PM
kwales   The circular logic that goes on here sometimes is ...   Mar 10 2010, 05:17 PM
kconway   I think the bottom line to this discussion is how ...   Mar 10 2010, 06:20 PM
Tom_T   I think the bottom line to this discussion is how...   Mar 10 2010, 10:19 PM
kwales   It's pretty simple to explain. Start yer co...   Mar 10 2010, 06:32 PM
kconway   It's pretty simple to explain. Start yer c...   Mar 10 2010, 07:03 PM
kwales   I'm just curious why you are even asking us? ...   Mar 10 2010, 07:22 PM
kconway   I'm just curious why you are even asking us? ...   Mar 10 2010, 08:56 PM
Dr Evil   Place your bets, place your bets :rolleyes: You h...   Mar 10 2010, 08:30 PM
McMark   :confused: Blast your transmission already. ...   Mar 10 2010, 10:36 PM
r_towle   NO! Forget the media you are using for a secon...   Mar 10 2010, 10:43 PM
kconway   NO! Forget the media you are using for a seco...   Mar 10 2010, 11:19 PM
r_towle   Axle shaft oil seals will let debris in. Rear spee...   Mar 10 2010, 11:46 PM
Eric_Shea   I don't think Kevin deserves all of the ...   Mar 11 2010, 08:20 AM
kwales   Kevin, Maybe I wasn't clear and you took it ...   Mar 11 2010, 09:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:42 AM
