| kconway |
Mar 9 2010, 06:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I was wondering if it would be safe to soda, bead or walnut shell blast my transmission whole if I taped off the vent and perhaps the part lines in the case as to not hit the seals? I have a newly rebuilt transmission I'd like to clean up without tearing back down again.
Kev |
| kconway |
Mar 10 2010, 06:20 PM
I think the bottom line to this discussion is how does the media get inside? I've heard alot of folks say no way, but haven't heard a good explanation as to how the media gets inside if you take the proper precautions. I qualified my question with at least the common sense to completely cover the vent, where else is it vulnerable. If there was another path, my garage floor would be a huge puddle of tranny fluid.
Hey, I was dumb enough to rattle can it, I'm sure I can muster the stupidity to blast it. (IMG:style_emoticons/default/biggrin.gif) |
| Tom_T |
Mar 10 2010, 10:19 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
I think the bottom line to this discussion is how does the media get inside? I've heard alot of folks say no way, but haven't heard a good explanation as to how the media gets inside if you take the proper precautions. I qualified my question with at least the common sense to completely cover the vent, where else is it vulnerable. If there was another path, my garage floor would be a huge puddle of tranny fluid. Hey, I was dumb enough to rattle can it, I'm sure I can muster the stupidity to blast it. (IMG:style_emoticons/default/biggrin.gif) Kev - the good & the bad about soda & fine walnut media are that the fineness doesn't destroy the rubber & plastic lenses on a car when say you're blasting the body, but it is also fine enough to find its way under pressure into the damnedest places! It just gets by the tiniest of cracks or gaps, as well as being able to make the adhesive on tape fail, etc., etc. This is the bane of fine media blasting! (IMG:style_emoticons/default/dry.gif) Any precautions which you take to close off all the gaps, vents, seals, etc. may or may not prevent any from getting inside a mechanical part such as a tranny. If it were a case prior to rebuilding, then you'd blast it, clean it & rebuild a clean case - but this is an operating tranny that we all presume you want to keep that way. So I guess - proceed at your own peril with medial blasting, or else try some of the other suggested paint removal & clean-up methods here! ... it's up to Bud, because you're writing the checks on your 914! (IMG:style_emoticons/default/confused24.gif) |
kconway Transmission Soda, Bead or Walnut Shell Blasting Mar 9 2010, 06:43 PM
McMark Soda would be the only thing I would even consider... Mar 9 2010, 06:47 PM
Vacca Rabite no. Mar 9 2010, 06:52 PM
Tom_T Kev -
Maybe just some POR Marine Clean away from ... Mar 9 2010, 07:03 PM
bandjoey Harbor Freight sells a spray bottle that attaches ... Mar 9 2010, 07:11 PM
kconway Truth be told, the DACO (Dumb Ass Current Owner) t... Mar 9 2010, 08:10 PM
Tom_T
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 9 2010, 08:48 PM
Vacca Rabite
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 10 2010, 07:38 AM
McMark Brake cleaner usually takes off rattle can paint R... Mar 9 2010, 09:52 PM
bigkensteele While I understand the apprehension to condone ful... Mar 9 2010, 11:24 PM
McMark I agree that soda is probably safe. I won't b... Mar 9 2010, 11:30 PM
Mark Henry I'd just stick it in and the 914 automatic cor... Mar 10 2010, 02:34 AM
ME733 ....Use as mcmark suggested- brake cleaner- first,... Mar 10 2010, 07:36 AM
sean_v8_914 I put my complete trans in my jet wash cabinet. st... Mar 10 2010, 08:23 AM
sean_v8_914 soda is an abrasive. does it disolve in oil? Mar 10 2010, 08:24 AM
tdgray Back the cart up boyz... some of you are saying th... Mar 10 2010, 09:10 AM
McMark I wouldn't blast assembled carbs and then thro... Mar 10 2010, 09:18 AM
Vacca Rabite When I blasted my carbs, the were out of the car a... Mar 10 2010, 10:08 AM
tdgray
When I blasted my carbs, the were out of the car ... Mar 10 2010, 12:19 PM
Eric_Shea I've personally seen walnut. It gives "p... Mar 10 2010, 10:15 AM
sean_v8_914 YES!!! even oven cleaner will eat it i... Mar 10 2010, 11:19 AM
kconway Are the gaskets between case part lines vulnerable... Mar 10 2010, 12:43 PM
Tom_T After blasting or cleaning - you may want to try a... Mar 10 2010, 01:56 PM
kwales The circular logic that goes on here sometimes is ... Mar 10 2010, 05:17 PM
kwales It's pretty simple to explain.
Start yer co... Mar 10 2010, 06:32 PM
kconway
Start yer c... Mar 10 2010, 07:03 PM
kwales I'm just curious why you are even asking us?
... Mar 10 2010, 07:22 PM
kconway
... Mar 10 2010, 08:56 PM
Dr Evil Place your bets, place your bets :rolleyes:
You h... Mar 10 2010, 08:30 PM
McMark
:confused:
Blast your transmission already. ... Mar 10 2010, 10:36 PM
r_towle NO!
Forget the media you are using for a secon... Mar 10 2010, 10:43 PM
kconway
NO!
Forget the media you are using for a seco... Mar 10 2010, 11:19 PM
r_towle Axle shaft oil seals will let debris in.
Rear spee... Mar 10 2010, 11:46 PM
Eric_Shea I don't think Kevin deserves all of the ... Mar 11 2010, 08:20 AM
kwales Kevin,
Maybe I wasn't clear and you took it ... Mar 11 2010, 09:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:41 AM |
