| kconway |
Mar 9 2010, 06:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I was wondering if it would be safe to soda, bead or walnut shell blast my transmission whole if I taped off the vent and perhaps the part lines in the case as to not hit the seals? I have a newly rebuilt transmission I'd like to clean up without tearing back down again.
Kev |
| Katmanken |
Mar 11 2010, 09:14 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Kevin,
Maybe I wasn't clear and you took it wrong. You wanted an answer on how blasting would allow the ingress of grit and I tried to give it to you in a graphic fashion. The reason that I used it is I've done a lot of sandblasting, and the grit riccochets off the surfaces and goes everywhere. To clean up, you shove an air nozzle inside your clothes to remove an amazing amount of sand and particles. Your face is coated in grit around the goggles, and when you use the nozzle to clean the sweat adhered particles from your face and hair, you will find that your lips can't be kept closed. No matter how hard you try. In that case, a water mouth rinse and spit removes most of the grit. The physics behind spreading your lips and spreading the seals/o-rings with air pressure is exactly the same. That is the point that I was trying to make and it came from blasting experience. And, somehow, the sand even managed to find it's way past my ear plugs and into my ears. I have also used duct tape to mask and it does a pretty good job resisting the blast media. Sand bounces off, but the tape wears over time. When the duct tape was peeled up, there were little channels of fine grit rammed under the tape and down any fold in the tape. These folds happen when the flat tape is applied to a non-flat surface. New tacky tape works much better at bouncing sand than a roll of old dried tape. I hope that helps. Ken |
kconway Transmission Soda, Bead or Walnut Shell Blasting Mar 9 2010, 06:43 PM
McMark Soda would be the only thing I would even consider... Mar 9 2010, 06:47 PM
Vacca Rabite no. Mar 9 2010, 06:52 PM
Tom_T Kev -
Maybe just some POR Marine Clean away from ... Mar 9 2010, 07:03 PM
bandjoey Harbor Freight sells a spray bottle that attaches ... Mar 9 2010, 07:11 PM
kconway Truth be told, the DACO (Dumb Ass Current Owner) t... Mar 9 2010, 08:10 PM
Tom_T
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 9 2010, 08:48 PM
Vacca Rabite
Truth be told, the DACO (Dumb Ass Current Owner) ... Mar 10 2010, 07:38 AM
McMark Brake cleaner usually takes off rattle can paint R... Mar 9 2010, 09:52 PM
bigkensteele While I understand the apprehension to condone ful... Mar 9 2010, 11:24 PM
McMark I agree that soda is probably safe. I won't b... Mar 9 2010, 11:30 PM
Mark Henry I'd just stick it in and the 914 automatic cor... Mar 10 2010, 02:34 AM
ME733 ....Use as mcmark suggested- brake cleaner- first,... Mar 10 2010, 07:36 AM
sean_v8_914 I put my complete trans in my jet wash cabinet. st... Mar 10 2010, 08:23 AM
sean_v8_914 soda is an abrasive. does it disolve in oil? Mar 10 2010, 08:24 AM
tdgray Back the cart up boyz... some of you are saying th... Mar 10 2010, 09:10 AM
McMark I wouldn't blast assembled carbs and then thro... Mar 10 2010, 09:18 AM
Vacca Rabite When I blasted my carbs, the were out of the car a... Mar 10 2010, 10:08 AM
tdgray
When I blasted my carbs, the were out of the car ... Mar 10 2010, 12:19 PM
Eric_Shea I've personally seen walnut. It gives "p... Mar 10 2010, 10:15 AM
sean_v8_914 YES!!! even oven cleaner will eat it i... Mar 10 2010, 11:19 AM
kconway Are the gaskets between case part lines vulnerable... Mar 10 2010, 12:43 PM
Tom_T After blasting or cleaning - you may want to try a... Mar 10 2010, 01:56 PM
kwales The circular logic that goes on here sometimes is ... Mar 10 2010, 05:17 PM
kconway I think the bottom line to this discussion is how ... Mar 10 2010, 06:20 PM
Tom_T
I think the bottom line to this discussion is how... Mar 10 2010, 10:19 PM
kwales It's pretty simple to explain.
Start yer co... Mar 10 2010, 06:32 PM
kconway
Start yer c... Mar 10 2010, 07:03 PM
kwales I'm just curious why you are even asking us?
... Mar 10 2010, 07:22 PM
kconway
... Mar 10 2010, 08:56 PM
Dr Evil Place your bets, place your bets :rolleyes:
You h... Mar 10 2010, 08:30 PM
McMark
:confused:
Blast your transmission already. ... Mar 10 2010, 10:36 PM
r_towle NO!
Forget the media you are using for a secon... Mar 10 2010, 10:43 PM
kconway
NO!
Forget the media you are using for a seco... Mar 10 2010, 11:19 PM
r_towle Axle shaft oil seals will let debris in.
Rear spee... Mar 10 2010, 11:46 PM
Eric_Shea I don't think Kevin deserves all of the ... Mar 11 2010, 08:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:41 AM |
