> Tubular Space Frame?, How would you do it?
plymouth37
post Mar 8 2010, 07:57 PM
So I have been playing with the idea of adding a couple more tubes to the back of the Anklebiter. If you were to replace the back half of a 914 with tubes where would you put them? Here is a rendering of the original cage (red), drivetrain (Grey), and points that need to be tied in (green).
What would you do?
WRX914
post Mar 11 2010, 09:17 AM
2.5 WRX STI hybrid powered beast
Ohhh to have the time to entertain these things!!!
Dana,
How's my old rommie doin? How is Becky? How is Laurie? Hope all is well.
plymouth37   Tubular Space Frame?   Mar 8 2010, 07:57 PM
plymouth37   Here is my first draft, any thoughts?   Mar 8 2010, 07:57 PM
SirAndy   any thoughts? Overkill? :confused:   Mar 8 2010, 08:24 PM
plymouth37   any thoughts? Overkill? :confused: This is the...   Mar 8 2010, 08:27 PM
SirAndy   I want it to be able to handle at least 500hp bu...   Mar 8 2010, 08:34 PM
plymouth37   RE: Tubular Space Frame?   Mar 8 2010, 08:11 PM
underthetire   Dam. Just cut the body off the pan and build a who...   Mar 8 2010, 08:18 PM
plymouth37   I would like to keep the passenger compartment int...   Mar 8 2010, 08:23 PM
URY914   RE: Tubular Space Frame?   Mar 8 2010, 08:28 PM
URY914   RE: Tubular Space Frame?   Mar 8 2010, 08:29 PM
SirAndy   Ury, that stock starter looks heavy ... :shades2:...   Mar 8 2010, 08:32 PM
plymouth37   I was thinking of yours when I was working on this...   Mar 8 2010, 08:32 PM
BigD9146gt   I was thinking of yours when I was working on thi...   Mar 9 2010, 03:30 AM
plymouth37   The plan would be to eliminate all sheet metal beh...   Mar 8 2010, 08:37 PM
SirAndy   More examples, some better, some not so much (IMHO...   Mar 8 2010, 08:42 PM
jd74914   I like the design you posted. You really do need m...   Mar 8 2010, 08:47 PM
Crazyhippy   The tube from the long too the motor mount wont be...   Mar 8 2010, 08:54 PM
plymouth37   Tube wall thickness is another factor, I like the ...   Mar 8 2010, 08:55 PM
Jeff Hail   Cost no object I would go the route Hari Matsuda w...   Mar 9 2010, 02:14 AM
Jeff Hail   Hari's latest configuration was this.   Mar 9 2010, 02:19 AM
URY914   500hp puts you in a different crowd than my car. H...   Mar 9 2010, 07:44 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:45 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:47 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:53 AM
URY914   RE: Tubular Space Frame?   Mar 9 2010, 07:55 AM
URY914   I have more pictures but I'd have to spend the...   Mar 9 2010, 08:03 AM
rick 918-S   A Celette would be slick for a tube chassis. You...   Mar 9 2010, 08:08 AM
Brett W   The 914 chassis is far from good. I think the fac...   Mar 9 2010, 09:52 AM
rick 918-S   The 914 chassis is far from good. I think the fa...   Mar 9 2010, 11:06 AM
FourBlades   :agree: :agree: :agree: Just build more stu...   Mar 9 2010, 11:35 AM
plymouth37   Thanks for the input guys, lots of great pics. I a...   Mar 9 2010, 10:41 AM
Rand   Top of shock tower (bridging the hidden gap betwee...   Mar 9 2010, 11:25 AM
URY914   You build it and some will like it, some won't...   Mar 9 2010, 11:45 AM
d914   some one needs to design a full tube frame car...t...   Mar 9 2010, 11:47 AM
URY914   some one needs to design a full tube frame car......   Mar 9 2010, 12:50 PM
plymouth37   You build it and some will like it, some won...   Mar 9 2010, 11:49 AM
J P Stein   Were I going to the trouble of building a tube fra...   Mar 9 2010, 01:42 PM
SirAndy   So I have been playing with the idea of adding a ...   Mar 9 2010, 02:15 PM
plymouth37   So I have been playing with the idea of adding a...   Mar 9 2010, 10:10 PM
jd74914   Are you still in school? If you are you should gra...   Mar 10 2010, 07:42 AM
plymouth37   Are you still in school? If you are you should gr...   Mar 10 2010, 02:12 PM
jd74914   That is actually a really good idea, the formula ...   Mar 11 2010, 09:34 AM
WRX914   Ohhh to have the time to entertain these things...   Mar 11 2010, 09:17 AM
plymouth37   Ohhh to have the time to entertain these things...   Mar 11 2010, 09:58 AM
YksKrad   I'm not too good with this kind of stuff, but ...   Mar 14 2010, 01:47 AM
Rand   My Qs are in blue. You already have the crosses to...   Mar 14 2010, 10:46 PM
sixnotfour   :idea:   Mar 14 2010, 10:54 PM
Dave_Darling   IIRC, the "Birdcage" Maser was a very ea...   Mar 14 2010, 11:54 PM
sixnotfour   :poke: 200 tubes   Mar 15 2010, 02:06 AM
jd74914   :poke: 200 tubes Eh, those are easy joints. The...   Mar 15 2010, 07:50 AM
sean_v8_914   chop chop!   Mar 15 2010, 04:00 PM
sean_v8_914   how much wire do ya think they used here?   Mar 15 2010, 04:01 PM
- Lo-Fi Version Time is now: 8th January 2026 - 05:16 PM
