| plymouth37 |
Mar 8 2010, 07:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
So I have been playing with the idea of adding a couple more tubes to the back of the Anklebiter. If you were to replace the back half of a 914 with tubes where would you put them? Here is a rendering of the original cage (red), drivetrain (Grey), and points that need to be tied in (green).
What would you do? Attached image(s)
| YksKrad |
Mar 14 2010, 01:47 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 14-February 05 From: Rolla, MO Member No.: 3,602 Region Association: Upper MidWest |
I'm not too good with this kind of stuff, but as far as solid works goes they have a nice set of tutorials on youtube http://www.youtube.com/user/solidworks... I believe they explicitly cover frame design in the tutorials. The FSAE team I'm on uses NX for frame design, I'm not sure what is used to analyze it though....
As I said I'm not very good at this, but squares are bad, triangles are good. These two seem to jump out at me. ![]() Sorry, but I can't give you much better advice. I haven't really been involved in that aspect of our car's design... |
plymouth37 Tubular Space Frame? Mar 8 2010, 07:57 PM
plymouth37 Here is my first draft, any thoughts? Mar 8 2010, 07:57 PM
any thoughts?
Overkill? :confused: Mar 8 2010, 08:24 PM
plymouth37
any thoughts?
This is the... Mar 8 2010, 08:27 PM
I want it to be able to handle at least 500hp bu... Mar 8 2010, 08:34 PM
plymouth37 RE: Tubular Space Frame? Mar 8 2010, 08:11 PM
underthetire Dam. Just cut the body off the pan and build a who... Mar 8 2010, 08:18 PM
plymouth37 I would like to keep the passenger compartment int... Mar 8 2010, 08:23 PM
URY914 RE: Tubular Space Frame? Mar 8 2010, 08:28 PM
URY914 RE: Tubular Space Frame? Mar 8 2010, 08:29 PM
SirAndy Ury, that stock starter looks heavy ... :shades2:... Mar 8 2010, 08:32 PM
plymouth37 I was thinking of yours when I was working on this... Mar 8 2010, 08:32 PM
BigD9146gt
I was thinking of yours when I was working on thi... Mar 9 2010, 03:30 AM
plymouth37 The plan would be to eliminate all sheet metal beh... Mar 8 2010, 08:37 PM
SirAndy More examples, some better, some not so much (IMHO... Mar 8 2010, 08:42 PM
jd74914 I like the design you posted. You really do need m... Mar 8 2010, 08:47 PM
Crazyhippy The tube from the long too the motor mount wont be... Mar 8 2010, 08:54 PM
plymouth37 Tube wall thickness is another factor, I like the ... Mar 8 2010, 08:55 PM
Jeff Hail Cost no object I would go the route Hari Matsuda w... Mar 9 2010, 02:14 AM
Jeff Hail Hari's latest configuration was this. Mar 9 2010, 02:19 AM
URY914 500hp puts you in a different crowd than my car. H... Mar 9 2010, 07:44 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:45 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:47 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:53 AM
URY914 RE: Tubular Space Frame? Mar 9 2010, 07:55 AM
URY914 I have more pictures but I'd have to spend the... Mar 9 2010, 08:03 AM
rick 918-S A Celette would be slick for a tube chassis. You... Mar 9 2010, 08:08 AM
Brett W The 914 chassis is far from good. I think the fac... Mar 9 2010, 09:52 AM
rick 918-S
The 914 chassis is far from good. I think the fa... Mar 9 2010, 11:06 AM
FourBlades
:agree: :agree: :agree:
Just build more stu... Mar 9 2010, 11:35 AM
plymouth37 Thanks for the input guys, lots of great pics. I a... Mar 9 2010, 10:41 AM
Rand Top of shock tower (bridging the hidden gap betwee... Mar 9 2010, 11:25 AM
URY914 You build it and some will like it, some won't... Mar 9 2010, 11:45 AM
d914 some one needs to design a full tube frame car...t... Mar 9 2010, 11:47 AM
URY914
some one needs to design a full tube frame car...... Mar 9 2010, 12:50 PM
plymouth37
You build it and some will like it, some won... Mar 9 2010, 11:49 AM
J P Stein Were I going to the trouble of building a tube fra... Mar 9 2010, 01:42 PM
So I have been playing with the idea of adding a ... Mar 9 2010, 02:15 PM
plymouth37
So I have been playing with the idea of adding a... Mar 9 2010, 10:10 PM
jd74914 Are you still in school? If you are you should gra... Mar 10 2010, 07:42 AM
plymouth37
Are you still in school? If you are you should gr... Mar 10 2010, 02:12 PM
jd74914
That is actually a really good idea, the formula ... Mar 11 2010, 09:34 AM
WRX914 Ohhh to have the time to entertain these things... Mar 11 2010, 09:17 AM
plymouth37
Ohhh to have the time to entertain these things... Mar 11 2010, 09:58 AM
Rand My Qs are in blue. You already have the crosses to... Mar 14 2010, 10:46 PM
sixnotfour :idea: Mar 14 2010, 10:54 PM
Dave_Darling IIRC, the "Birdcage" Maser was a very ea... Mar 14 2010, 11:54 PM
sixnotfour :poke: 200 tubes Mar 15 2010, 02:06 AM
jd74914
:poke: 200 tubes
Eh, those are easy joints. The... Mar 15 2010, 07:50 AM
sean_v8_914 chop chop! Mar 15 2010, 04:00 PM
sean_v8_914 how much wire do ya think they used here? Mar 15 2010, 04:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th January 2026 - 05:16 PM |
