Another rear suspension idea, raising the rear trailing points |
bam914 |
Mar 13 2010, 09:05 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
So there have been a few different ways people on here have raised their rear mounts. Here is my way. I will be able to adjust my roll center by shimming the pickup points on the mount. I will also be able to adjust camber separate of the roll center. I have a few more braces to make before it is all done.
J P Stein |
Mar 14 2010, 08:59 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Just my non-engineer .02.
Were it me, I would put the hiem joint attach points in double shear using a C section and tie in the supports at the same level of the pivot point. Your present set up gives the applied forces a mechanical advantage over the structure intended to hold it. Overall, I like the concept but, as is, doubt it's integrity. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:09 AM |
