| flat4tom |
Mar 17 2010, 05:51 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 6-January 10 From: Shingletown CA Member No.: 11,207 Region Association: Northern California |
Hello all,
Got my 914 back together today. Here's a list of what I've done since I brought it home... Fixed front trunk release so it will open. Pulled gas tank. Tank is clean, no rust, fuel sock there in good shape. Replaced all fuel lines under tank. Pulled injectors and sent them for servicing. Replaced all vacuum hoses. Tightened all intake runners down - they were loose. Removed and cleaned the throttle body Checked the TPS and adjusted Replaced the throttle body, installed a new TB gasket. Removed and fixed inoperative AAR. Replaced the spark plugs with new NGK's Reinstalled cleaned and serviced fuel injectors. All new fuel hoses in the engine compartment. She runs like a top now! No vacuum leaks. No missing. Idles smooth. Took her out for a spin and to get some gas. Has a strange issue now with the fuel pump. The fuel pump has been relocated to the front under the gas tank - recommended relocation spot. I can now hear the pump running while the engine is running. Seemed like it was quieter before... anyway... While driving down the road straight - all is good. If I make a turn to the left the fuel pump seems to cut out (the sound changes) and the engine starves for fuel. Right turns, no problem. (IMG:style_emoticons/default/WTF.gif) If it's idling in the driveway and I turn the wheels, no problem - fuel pressure remains constant. I wish I could check my fuel pressure gauge while driving but it's mounted to a fuel rail. Any thought why the pump would cut out on left turns?? Any suggestions on where to look for this? I am so close to being able to drive her!!... (IMG:style_emoticons/default/driving.gif) T.I.A. Tom '73 2.0 |
Tom_T Check anything that could move in the direction of... Mar 17 2010, 06:05 PM
SUNAB914 Pinched fuel line with weight shift? Mar 17 2010, 07:16 PM
MecGen Hi
You know those little rubber lines on the bott... Mar 17 2010, 07:43 PM
vsg914 clogged fuel filter. Chashed that problem for a mo... Mar 17 2010, 07:49 PM
kwales Noisy pump can mean there is a flow problem or a f... Mar 18 2010, 08:19 AM
flat4tom Thx for the replies.
Some more info:
The fuel ... Mar 18 2010, 09:21 AM
kwales The problem might be the non-stock wiring added du... Mar 18 2010, 09:39 AM
flat4tom
The problem might be the non-stock wiring added d... Mar 19 2010, 10:04 AM
vsg914 sits for 3 years? Have you changed the filter? Or ... Mar 18 2010, 06:41 PM
kwales I think vgs914 is spot on
I guess one of the ques... Mar 19 2010, 11:09 AM
flat4tom Hello everyone,
Just to followup on my post and w... Mar 22 2010, 09:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 12:09 AM |
