buhs914 |
Not So Newbie ![]() ![]() Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region ![]() |
Well i finished doing my front brakes and fixing some other little stuff and decided to take the car out for a drive. Well i had to jump start it since the battery is dead. It took a bit to get it to run smooth but once i got it, it ran great. I took it out for a lap around the nearby block and about halfway around the loop i started hearing some sounds from the left tires and then a big thump and the left rear side dropped down. I jumped out of the car to see wtf just happened and i found that out of my rush to drive my car i had forgot to check the rear lug nuts and the rear left tire came off (IMG:style_emoticons/default/dry.gif) it dented up the rear fender.. and not only that but the front left tire went completely flat (IMG:style_emoticons/default/mad.gif) ugh
after getting the wheel back on and changing the tire i jumped and restarted the disaster and drove it back to my house. It seemed to drive just fine and the brakes worked great but now my fender is bent up... i guess i have more to do tomorrow (IMG:style_emoticons/default/dry.gif) ugh i am a dumbass |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
You'll never forget that experience....move along. NOW go charge the battery. You'll kill the alternator with a flat battery.
Alts maintain batteries and are not designed to bring it up from a low charge. 2 amps on a battery charger with the ground disconnected. |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:37 PM |
