> Strange Fuel Pump Issue, Help please - FIXED!
flat4tom
post Mar 17 2010, 05:51 PM
Hello all,
Got my 914 back together today. Here's a list of what I've done since I brought it home...
Fixed front trunk release so it will open.
Pulled gas tank. Tank is clean, no rust, fuel sock there in good shape.
Replaced all fuel lines under tank.
Pulled injectors and sent them for servicing.
Replaced all vacuum hoses.
Tightened all intake runners down - they were loose.
Removed and cleaned the throttle body
Checked the TPS and adjusted
Replaced the throttle body, installed a new TB gasket.
Removed and fixed inoperative AAR.
Replaced the spark plugs with new NGK's
Reinstalled cleaned and serviced fuel injectors.
All new fuel hoses in the engine compartment.
She runs like a top now! No vacuum leaks. No missing. Idles smooth. Took her out for a spin and to get some gas. Has a strange issue now with the fuel pump.
The fuel pump has been relocated to the front under the gas tank - recommended relocation spot. I can now hear the pump running while the engine is running. Seemed like it was quieter before... anyway...
While driving down the road straight - all is good. If I make a turn to the left the fuel pump seems to cut out (the sound changes) and the engine starves for fuel.
Right turns, no problem. (IMG:style_emoticons/default/WTF.gif) If it's idling in the driveway and I turn the wheels, no problem - fuel pressure remains constant. I wish I could check my fuel pressure gauge while driving but it's mounted to a fuel rail.
Any thought why the pump would cut out on left turns?? Any suggestions on where to look for this?
I am so close to being able to drive her!!... (IMG:style_emoticons/default/driving.gif)
T.I.A.
Tom
'73 2.0
Katmanken
post Mar 18 2010, 09:39 AM
You haven't seen me if anybody asks...
The problem might be the non-stock wiring added during the pump relocation. Start the engine and wiggle the wires at the pump and where they tie in to the factory wiring to see if it makes the problem come and go.
If that makes a change, there's your problem to fix.
Sitting for three years with old gas can cause varnish and crud to cake in your pump or rust to form in your tank. Did you drain your tank and get new gas?
flat4tom
post Mar 19 2010, 10:04 AM
QUOTE(kwales @ Mar 18 2010, 08:39 AM) *
I did pull the tank to replace the lower fuel lines. They were all hard as rock and rotted. The tank is clean - no rust that I could see. The entire fuel system is new now with the exception of the pump. New filter, new lines under the tank, new lines in tunnel, new upper fuel lines in the engine compartment, cleaned and serviced fuel injectors. The car purrs now except when turning to the left when it chokes out.
I'm thinking either the pump is bad, or one of the replaced fuel lines is kinking, or almost fully kinked.
I'll be jacking up the front this weekend and take a look at the fuel lines looking for a kink in them. I'll also check the electrical connection to the pump.
After that...who knows. Probably replace the pump
Thx for the replies.
Tom
- Lo-Fi Version Time is now: 13th November 2026 - 12:09 AM
