Fuel Pump Diagnostics |
solex |
Mar 21 2010, 12:40 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi All,
Need a little help to diagnose a fuel pump problem in a 75, I do not hear the pump when I turn the key to the run position. The car was running, I had a few occasions where it would not start, let it sit for a few days and it was start right up. The grounds: under the relay board, battery and transmission have all been cleaned. All fuses are good. The relay is working as I can hear it click into position. When the key is in the run position relay terminals 30 and 85 shows 12 volts. Terminal 86 show 0.03 volts and terminal 87 show zero volts. There is no voltage at either of the fuel pump terminals. The readings at the relay is counter to to what Haynes states (86 should read 12 and 85 should be ground). I not sure where to check next, really do not want to pull the tank. Any assistance would be appreciated. Thanks, Dan |
Mike Bellis |
Mar 21 2010, 11:28 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
30 is power from tha battery
85 is pump on power from the ECU 86 is ground 87 is power out to the pump. Put a jumper wire from 30 to 87. You should hear the pump. The pump wires should have power. Your relay may "click" and still be bad. |
914_teener |
Mar 21 2010, 11:57 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
30 is power from tha battery 85 is pump on power from the ECU 86 is ground 87 is power out to the pump. Put a jumper wire from 30 to 87. You should hear the pump. The pump wires should have power. Your relay may "click" and still be bad. I had a crack in the hot wire next to the pump about 2 inches back of the connector. Inspect it well before you start tearing things apart.....how do I know this? Also spreading the relay pins and contact cleaner also is a great idea. How do I know this too? Good luck. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:09 AM |
