> New Carb linkage for /4 engines- RAT "Accu-Link", Another approach for the solution of a long time issue.
Jake Raby
post Oct 1 2009, 11:17 AM
Engine Surgeon
This is a sneak peek of the new cable linkage system that we have been working to complete for quite a while now.. Available (SOON!) for carburetors or our "Extrudabody" EFI throttle bodies.
These pics are of the first fitment of the new arrangement onto a pair of EMPI HPMX carbs on our display fixture. There are several changes necessary, but for a first mock up and fitment the system worked better than we'd imagine. The final kit will have all anodized parts, full hardware and etc included along with an installation DVD produced by yours truly.
There have been efforts by others to complete a system like this,(some with great results) but to date nothing has been universally applicable or commercially available using this method of actuation and synchronization. There has also not been an attempt made to replace the OEM throttle cable all the way to the throttle pedal.
The difference in this system is that the permanently lubricated sheathed cables will replace the ENTIRE throttle cable arrangement all the way to the pedal. This will be accomplished with a system thats comprised of one primary cable from the pedal to an intermediate link housing that will tie both cables together. The high quality, multi-role intermediate link will also have the adjustment and return spring for the arrangement in a combined unit.
The intermediate link will reside above the transaxle and will triple as a quick disconnection point should the service of the engine/ carbs need to be carried out. This intermediate link is one bad ass, yet VERY SIMPLE part!
The secondary cable couples to the primary cable via the intermediate link then travels around a billet cam on the "lead" carburetor/ throttle body. This cable then continues through another sheathed cable to the "slave" throttle body/ Carburetor.
The benefits of the cable system are numerous.. I personally like the lightweight yet very robust construction coupled to the fact that it omits the factory throttle cable and replaces it all with new much stronger parts. It's also easy to custom tailor pedal feel and throttle actuation with adjustments made to the cams and cable tensions.
I have been "over" Hex bar linkage systems and their inherent issues for years.. Bellcrank systems have proven to be expensive and can be problematic with engines that have greater expansion levels as their synchronization is effected as the engine "grows". With this system is doesn't matter how much the engine expands the cables retain their tension.
This is the smoothest and most accurate means of carburetor actuation I have experienced to date.
Here are some features:
-Universally applicable for all Weber IDF/ EMPI HPMX and Dellorto DRLA applications for the Type 1, Type 4 or Porsche 356 engine!! The same kit can fit all these different engines! The same kit can also fir a Type 3 or Type 4 engine using these carburetors with the stock pancake cooling system.
-With very slight changes this same kit can actuate a set of 48 IDAs on any of the above engines as well.
-High quality billet throttle cams allow for easy adjustment of the system for various pedal arrangements
-The entire stock throttle cable is removed and replaced with the "accu-link" components
-The intermediate link allows for ease of adjustment, a quick disconnection point, coupling of the primary and secondary cables and a redundant throttle return spring all in one self contained, snap together housing.
- The sheathed cables are adjustable in 7 different locations for ease of tuning the system to the vehicle, driver and carburetors.
-Engine width and expansion will not alter carburetor/ throttle body actuation or synchronization at all.
- Very light carb return springs are able to be used due to the ease of actuation and the slippery sheathed cables. This allows for a nice pedal feel without giving up snappy throttle action
-Carburetor throttle shaft bearings/ bushings will see reduced loads and will live longer.
- No mechanical parts to wear out like ball sockets and heim joints/ spherical bearings. When the cables begin to stretch the adjustment can be made to them in 7 different places throught the arrangement. Spare cables can be sold for pennies to keep in the glove box..
- No heavy mechanical linkages to attach to the throttle shafts and transmit harmonics to the throttle shafts, thus chattering the accelerator pumps making them dribble fuel down the intakes.. This is a tuning issue that many people fight and do not even realize it.
- Its different! As different as a DTM cooling system or a big bore Type 4!
-Its also going to be very cost effective with all parts (except the throttle intermediate link) made in the USA including the cables, billet throttle cams and etc. The throttle intermediate link is made in Germany and has been proven in the 24 hours of Le Man as recently as this past June :-)
And as of today the Patent pending processes have been initiated!
This post has been edited by Jake Raby: Oct 1 2009, 11:19 AM
HAM Inc
post Mar 22 2010, 11:17 AM
I found with one CB hex bar that I set-up that the ratio's were different from one arm to the other, meaning that one carb was getting more travel than the other. I had to drill a new hole for the drop link on one arm to reduce its ratio. Nothing else worked! Drilled the new hole and it worked fine. Both carbs synched up perfect.
tat2dphreak
post Mar 22 2010, 11:33 AM
stoya, stoya, stoya
QUOTE(HAM Inc @ Mar 22 2010, 12:17 PM) *
(IMG:style_emoticons/default/agree.gif) we did the same thing... redrilled the holes and re-tapped to match the travel, and geometry.
jeffdon
post Mar 23 2010, 08:55 AM
I had an idea for making up a cable linkage (see drawing). Obvviously I have left off things like the mounting for cables at carb side and throttle pedal side, and the drawing is not to scale, but basically the idea is a slider arrangement that incorporates a one cable to two as the key. Seems like you could do all your linkage adjusting at the cable ends and have no effect from engine expansion as the cables to the carbs themselves are not effected.
Am I missing something fundamental here? Seems like it would be pretty simple.Attached Image
r_towle
post Mar 23 2010, 06:55 PM
Custom Member
QUOTE(jeffdon @ Mar 23 2010, 10:55 AM) *
Go to a motorcycle shop or a snow mobile shop.
Your design with the tube is industry standard...lots of options to buy off the shelf.
None that I found addressed the connection to the unique factory cable.
Jake,
You mentioned that you are replacing the cable all the way to the pedal...
Are you using one cable for the whole thing? (I ask because the long cable to the pedal will break...just part of the facts of life)
Also, when do you suspect you will have a weber solution?
I am close (a month away from install of my motor) and I would buy the parts kit and make up one....I already have one built, but I like your solution alot more...its elegant.
Got everything within .5 grams...good enough for a street car.
Rich
Jake Raby   New Carb linkage for /4 engines- RAT "Accu-Link"   Oct 1 2009, 11:17 AM
ghuff   That stainless braid looks so badass and gangster ...   Oct 1 2009, 11:42 AM
FourBlades   I want one. :trophy: :trophy: :trophy: I am ...   Oct 1 2009, 11:46 AM
SUNAB914   Any ideas on cost yet? I would seriously consider ...   Oct 1 2009, 11:47 AM
Jake Raby   These are non compressable sheaths.. The cable is ...   Oct 1 2009, 11:48 AM
ghuff   These are non compressable sheaths.. The cable is...   Oct 1 2009, 11:58 AM
URY914   Seems way too simple.   Oct 1 2009, 11:56 AM
Jake Raby   The ECU is in my 912E now... I need to download ...   Oct 1 2009, 12:10 PM
9146986   Great work Jake! This is long overdue.   Oct 1 2009, 01:22 PM
tat2dphreak   this looks great, Jake! be sure and let us kno...   Oct 1 2009, 01:44 PM
jmill   I like it. Beats the heck out of anything I'v...   Oct 1 2009, 02:13 PM
Jake Raby   Throttle idle stop is on the opposite side of the ...   Oct 1 2009, 02:17 PM
underthetire   looks like my dirtbike set-up ! cool !   Oct 1 2009, 03:12 PM
flipb   I might wait to convert my 2.0 from single Weber p...   Oct 1 2009, 03:14 PM
Jake Raby   Can **I** demolish the single carb?? LOL.. I got ...   Oct 1 2009, 03:24 PM
tomeric914   Why must you continue to taunt me with products I ...   Oct 1 2009, 03:34 PM
Jake Raby   Why must you continue to taunt me with products I...   Oct 1 2009, 03:42 PM
jhadler   Could this work on other throttle body setups as w...   Oct 1 2009, 03:48 PM
Jake Raby   With mods I am sure it could... The TWMs have real...   Oct 1 2009, 03:52 PM
jhadler   With mods I am sure it could... The TWMs have rea...   Oct 1 2009, 04:09 PM
BarberDave   :trophy: Jake : We expect nothin...   Oct 1 2009, 04:06 PM
Jake Raby   :trophy: Jake : We expect nothi...   Oct 1 2009, 04:21 PM
degreeoff   the only issue I see is where the main joins the c...   Oct 1 2009, 04:42 PM
Jake Raby   Actually thats only ONE cable! It has a barrel...   Oct 1 2009, 05:01 PM
Vacca Rabite   Jake this is really cool. Now that I have seen it...   Oct 1 2009, 07:07 PM
Jake Raby   Yep!!! A few people have made their ow...   Oct 1 2009, 08:14 PM
ghuff   Yep!!! A few people have made their o...   Oct 1 2009, 11:28 PM
Mark Henry   Yep!!! A few people have made their ...   Oct 2 2009, 03:58 AM
ghuff   [quote name='ghuff' post='1220918' date='Oct 2 20...   Oct 2 2009, 11:32 PM
scotty b   Long anough for oh.... say...... a bus with a 6 in...   Oct 1 2009, 08:22 PM
Jake Raby   This will fit a six also...   Oct 1 2009, 08:51 PM
jd74914   This is a sneak peek of the new cable linkage sys...   Oct 1 2009, 08:59 PM
Jake Raby   We've been working on several projects with ex...   Oct 1 2009, 09:00 PM
jd74914   That's awesome! Thanks for the heads up. :...   Oct 1 2009, 09:01 PM
STP   This looks very cool. I'm tired of my Hexbar...   Oct 1 2009, 09:55 PM
Jake Raby   it's already working.. Just gotta optimize it.   Oct 1 2009, 10:05 PM
RJMII   That is a slick looking setup! I've got a ...   Oct 1 2009, 10:12 PM
Sleepin   Wow! Everything seems so simple once you actua...   Oct 1 2009, 10:53 PM
Rod   The best ideas are always the simplest. Go Jake. ...   Oct 2 2009, 05:36 AM
7275914911   Jake, Will this work on carbs that one pulls/push...   Oct 2 2009, 06:37 AM
Jake Raby   For this to work both carbs will have to rotate in...   Oct 2 2009, 04:30 PM
RJMII   how simple would it be to make it so they didn...   Oct 2 2009, 04:51 PM
Jake Raby   Anything is possible..A version like this would ha...   Oct 2 2009, 05:01 PM
HAM Inc   I freakin" can't wait to ditch the hex ba...   Oct 2 2009, 05:23 PM
McMark   This is similar to what I've been carrying aro...   Oct 2 2009, 07:33 PM
Jake Raby   I now have a tentative price... 159.00 per kit.. T...   Oct 2 2009, 08:18 PM
flipb   Do you also anticipate selling carb kits that incl...   Oct 2 2009, 08:22 PM
Jake Raby   Do you also anticipate selling carb kits that inc...   Oct 2 2009, 08:38 PM
URY914   Let me be the first to point out that this new sys...   Oct 2 2009, 08:49 PM
tat2dphreak   I only wish I hadn't just bought a new linkage...   Oct 2 2009, 08:51 PM
Jake Raby   It is light!!Very light! Otherwise Len...   Oct 2 2009, 09:03 PM
brer   looking good.   Oct 2 2009, 11:53 PM
craig downs   I like it. I was thinking on making a cable linkag...   Oct 3 2009, 12:29 AM
FourBlades   I am definitely in for 1 and maybe for 2 if they w...   Oct 3 2009, 08:00 AM
ConeDodger   If you want to sell volume in this Jake, trademark...   Oct 3 2009, 10:08 AM
Jake Raby   Bugpack is my choice for the re-seller in the T1 w...   Oct 3 2009, 11:22 AM
biosurfer1   Any update on this? I'm ready to "adjust...   Jan 2 2010, 06:29 PM
McMark   Jake's gone til Monday, then he'll be catc...   Jan 2 2010, 07:05 PM
ConeDodger   Jake's gone til Monday Killin' Wild Boa...   Jan 3 2010, 12:33 AM
turnaround89   Spring would be perfect, i really want one of thes...   Jan 2 2010, 11:04 PM
bandjoey   With this low friction material and life turn it i...   Jan 3 2010, 12:50 AM
SGB   I'm ready too. Did the roller cam setup ever ...   Jan 3 2010, 01:03 AM
JmuRiz   I'm ready too. Did the roller cam setup ever...   Jan 5 2010, 10:52 AM
DBCooper   That linkage is exactly what's been on the BMW...   Jan 3 2010, 07:48 AM
RobW   Super Cool! :cheer:   Jan 3 2010, 08:15 AM
jmill   They do sell pre-stretched cable. They've bee...   Jan 3 2010, 07:31 PM
scotty b   How much load do you guys plan on putting on this ...   Jan 3 2010, 07:53 PM
DBCooper   I don't know. They've been making BMW box...   Jan 3 2010, 10:46 PM
turnaround89   it may not be perfect, but i think it will work a ...   Jan 4 2010, 01:02 AM
Joe Ricard   Hex bar was designed by a retard.   Jan 5 2010, 12:11 AM
geniusanthony   Worse yet is the chinese company that "copied...   Jan 5 2010, 12:52 AM
crash914   hmmm.. got a 94 oil head. got a twin max. I KNOW...   Jan 5 2010, 04:00 AM
Jake Raby   One of the biggest parts of this development has b...   Jan 5 2010, 10:07 AM
Jake Raby   Roller development is done for the 2270, I have be...   Jan 5 2010, 01:40 PM
JmuRiz   Excellent! Does it still have the small carbs ...   Jan 5 2010, 02:38 PM
Jake Raby   Just 40mm Dells.. Thats all it has needed and I kn...   Jan 5 2010, 07:00 PM
turnaround89   Glad to hear the testing is going well, can't ...   Jan 5 2010, 07:41 PM
Jake Raby   Based on all the initial interest we have had I ex...   Jan 5 2010, 07:49 PM
r_towle   Consider making it totally hidden. That would cert...   Jan 5 2010, 08:00 PM
Jake Raby   Consider making it totally hidden. That would cer...   Jan 6 2010, 07:52 PM
eric914   Yep!!! A few people have made their o...   Jan 6 2010, 03:22 PM
biosurfer1   Well after working on my stupid crossbar linkage f...   Mar 22 2010, 11:12 AM
HAM Inc   I found with one CB hex bar that I set-up that the...   Mar 22 2010, 11:17 AM
tat2dphreak   I found with one CB hex bar that I set-up that th...   Mar 22 2010, 11:33 AM
jeffdon   I had an idea for making up a cable linkage (see d...   Mar 23 2010, 08:55 AM
Van   I had an idea for making up a cable linkage (see ...   Mar 23 2010, 12:26 PM
r_towle   I had an idea for making up a cable linkage (see ...   Mar 23 2010, 06:55 PM
Vacca Rabite   Wish these were on the market now. I am redoing m...   Mar 23 2010, 10:10 AM
biosurfer1   Me too Zach...I just hate screwing with the hex ba...   Mar 23 2010, 11:44 AM
tat2dphreak   :agree: the CB performance setup is a comparable ...   Mar 23 2010, 11:49 AM
jeffdon   :agree: the CB performance setup is a comparable...   Mar 23 2010, 11:53 AM
biosurfer1   I've looked at the bellcrank setup and it seem...   Mar 23 2010, 11:57 AM
jeffdon   I've looked at the bellcrank setup and it see...   Mar 23 2010, 12:08 PM
Jake Raby   I had hoped to have this on the market now.. But t...   Mar 23 2010, 01:13 PM
Cevan   While I'm waiting for engine parts for my buil...   Mar 23 2010, 01:30 PM
Van   Chris, you seem to be a master mechanic and a mast...   Mar 23 2010, 02:38 PM
jeffdon   Chris, you seem to be a master mechanic and a mas...   Mar 23 2010, 02:41 PM
jeffdon   Here is a pic of the bellcrank. Sorry about the q...   Mar 23 2010, 02:52 PM
Van   By the way, what shade of silver is your car? ...   Mar 23 2010, 03:39 PM
Vacca Rabite   Jake, if you need a test vehicle, my car is ready ...   Mar 23 2010, 06:31 PM
- Lo-Fi Version Time is now: 15th November 2026 - 06:03 AM
