V8 and liquid cooled guys..., Want to install a heater??? Here's mine |
Mike Bellis |
Mar 23 2010, 10:32 PM
It gets cold here in Northern California often in the moorning. So I decided to build a liquid heater. First, I spent some time measuring the inside of the fresh air box. I figured I could fit a core 11x6 maximum. my son and I spent several hours at the local Pick and Pull junk yard. I settled on a Transmission cooler from a late model Ford Truck. Cooler measures 10x6.
I quick placement and I realize I need to cut! The water dam for the fan must be cut down. Make sure not to cut all of it so that it will still keep some water off the motor. The finish cut to the dam. Ready for the lid? Not yet. |
Mike Bellis |
Mar 24 2010, 05:59 PM
The core I used has 3/8 NPT fittings and I'm using 1/2 inch hose barbs. Ideally this would be 5/8 hose barbs. The tranny cooler has more hot water surface area than a standard heater core, I think the 1/2 will give enough hot water. Anything is better than cold air!
Lo-Fi Version | Time is now: 11th June 2024 - 10:18 PM |
