G Man |
Newbie ![]() Group: Members Posts: 20 Joined: 28-February 10 From: Carson City NV Member No.: 11,415 Region Association: None ![]() |
Has anyone looked into swapping in an entire engine trans combo from a FWD car into a 914? Something like Honda, Mitsubishi, VW...I was thinking that you could keep the transverse engine configuration and just transplant the entire drivetrain. The only issue I can think of is that the engine may need to be moved toward the rear of the car so the axles will line up with the hubs. I'm guessing this would require some cutting into the rear trunk area. I searched for this topic and didn't find much. Thanks.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,730 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
As always, depends on how much YOU want to put into any conversion. Changing the configuration of a car is a big deal. Lots of downtime, welding, fabbing, things not working......sounds like R&D to me.
I've learned to leave what the factory set up pretty much alone. 914-6 conversions make sense. Fiero caddy conversions make sense etc. Mounting a transverse config in a 914, nah, not for me anyway. You want that, go buy a Fiero, grab a $500 4.9 caddy and do the swap. I did once, thing was a blast, got dam near 30mpg if driven "normal" and wieghed 40lbs less than the iron block V6 did! Plus it was easy to do. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 07:59 PM |
