225x55x15 tire - where to purchase?, Is this an obsolete size? |
mepstein |
Mar 28 2010, 07:45 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm flaring the rear and want to run 225x55x15 to keep diameter the same as previous tire but when I search for tires, I don't see any available in this size at the big chain/discount tire stores. Is this size still avalable and if so, where are you getting your tires? Thanks, Mark
dr914@autoatlanta.com |
Mar 28 2010, 11:19 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I'm flaring the rear and want to run 225x55x15 to keep diameter the same as previous tire but when I search for tires, I don't see any available in this size at the big chain/discount tire stores. Is this size still avalable and if so, where are you getting your tires? Thanks, Mark Should be 225 50 15 that is the usual size used on the rear 7 inch or 8 inch wheel under the rear flare. 205 55 15 in the front on a seven |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:44 PM |
