> Which JDM Subaru motor to use for conversion?, Ej20G or EJ20K or ???
bfrymire
post Mar 27 2010, 06:57 PM
Salsaholic
I hope someone can lend some light on this...
I am at the point to buy the motor. (Missed out on budmans motor.)
So, which one to buy?
Options:
EJ20 G
About 240hp, coil on plug. I think this has smaller turbo, so, should spool faster. On our small cars, this may not matter much.
Ej20 K
About 280Hp, center mounted coil (dual) and uses wasted spark. I think this has larger turbo. Not sure. I have been using wikipedia for a resource, and there is not a whole lot of detail.
As near as I can tell, I will need to get an external ignitor for either of these. Can someone jump in and clear this up?
I appreaciate any help on this.
-- brett
d914
post Mar 28 2010, 04:08 PM
lots of questions on the K and longivity.... I have a K and not running yet.. My overplan doesnt place alot of emphasis on the block serviving long.. For a $1k you can get a rebuilt short block.... The K has a bigger turbo and your looking at more HP... check out the nasioc.com for the discussions... Nothing really clear... Coil over plug is probably nicer..
and for the record I went with an aftermarket computer and new wire harness, $1500 option, but much simplier..
Also if your near LA, outfront, use to be outback. has lots of nice little pieces, computers, engines and short blocks....They specialize in suby powered rails..
bfrymire   Which JDM Subaru motor to use for conversion?   Mar 27 2010, 06:57 PM
dr914@autoatlanta.com   ask greg dundero he regularly posts to this site. ...   Mar 27 2010, 08:14 PM
DBCooper   I can't help as to which motor is better, but ...   Mar 28 2010, 03:32 PM
bfrymire   I can't help as to which motor is better, but...   Mar 28 2010, 05:42 PM
d914   lots of questions on the K and longivity.... I hav...   Mar 28 2010, 04:08 PM
bfrymire   lots of questions on the K and longivity.... I ha...   Mar 28 2010, 05:46 PM
bfrymire   Ok. So, I am thinking of getting this motor: htt...   Mar 28 2010, 09:45 PM
GS Guy   Be sure to add up all the costs before deciding wh...   Mar 29 2010, 10:19 AM
bfrymire   Be sure to add up all the costs before deciding w...   Mar 29 2010, 12:48 PM
DBCooper   I second that, research it well. There are lots o...   Mar 29 2010, 11:19 AM
bfrymire   I second that, research it well. There are lots ...   Mar 29 2010, 12:50 PM
pktzygt   I have an EJ20G but it's one of the varients w...   Mar 29 2010, 12:21 PM
bfrymire   I have an EJ20G but it's one of the varients ...   Mar 29 2010, 12:55 PM
pktzygt   I have an EJ20G but it's one of the varients...   Mar 29 2010, 08:12 PM
r_towle   can you flip the ring and pinion in a subaru trann...   Mar 29 2010, 08:24 PM
bfrymire   can you flip the ring and pinion in a subaru tran...   Mar 29 2010, 08:41 PM
DBCooper   can you flip the ring and pinion in a subaru tra...   Mar 29 2010, 09:39 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:31 PM
