| bfrymire |
Mar 27 2010, 06:57 PM
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I hope someone can lend some light on this...
I am at the point to buy the motor. (Missed out on budmans motor.) So, which one to buy? Options: EJ20 G About 240hp, coil on plug. I think this has smaller turbo, so, should spool faster. On our small cars, this may not matter much. Ej20 K About 280Hp, center mounted coil (dual) and uses wasted spark. I think this has larger turbo. Not sure. I have been using wikipedia for a resource, and there is not a whole lot of detail. As near as I can tell, I will need to get an external ignitor for either of these. Can someone jump in and clear this up? I appreaciate any help on this. -- brett |
| pktzygt |
Mar 29 2010, 12:21 PM
Member ![]() ![]() Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
I have an EJ20G but it's one of the varients without the coil on plug. I'm still sorting through the details to get the EM I want to use for it though. That one on ebay looks good to me. Don't forget that you might be able to get $1000 back when you sell the transmission like I did.
bfrymire Which JDM Subaru motor to use for conversion? Mar 27 2010, 06:57 PM
dr914@autoatlanta.com ask greg dundero he regularly posts to this site. ... Mar 27 2010, 08:14 PM
DBCooper I can't help as to which motor is better, but ... Mar 28 2010, 03:32 PM
bfrymire
I can't help as to which motor is better, but... Mar 28 2010, 05:42 PM
d914 lots of questions on the K and longivity.... I hav... Mar 28 2010, 04:08 PM
bfrymire
lots of questions on the K and longivity.... I ha... Mar 28 2010, 05:46 PM
bfrymire Ok. So, I am thinking of getting this motor:
htt... Mar 28 2010, 09:45 PM
GS Guy Be sure to add up all the costs before deciding wh... Mar 29 2010, 10:19 AM
bfrymire
Be sure to add up all the costs before deciding w... Mar 29 2010, 12:48 PM
DBCooper I second that, research it well. There are lots o... Mar 29 2010, 11:19 AM
bfrymire
I second that, research it well. There are lots ... Mar 29 2010, 12:50 PM
bfrymire
I have an EJ20G but it's one of the varients ... Mar 29 2010, 12:55 PM
pktzygt
I have an EJ20G but it's one of the varients... Mar 29 2010, 08:12 PM
r_towle can you flip the ring and pinion in a subaru trann... Mar 29 2010, 08:24 PM
bfrymire
can you flip the ring and pinion in a subaru tran... Mar 29 2010, 08:41 PM
DBCooper
can you flip the ring and pinion in a subaru tra... Mar 29 2010, 09:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:56 PM |
