> Which JDM Subaru motor to use for conversion?, Ej20G or EJ20K or ???
bfrymire
post Mar 27 2010, 06:57 PM
Salsaholic
I hope someone can lend some light on this...
I am at the point to buy the motor. (Missed out on budmans motor.)
So, which one to buy?
Options:
EJ20 G
About 240hp, coil on plug. I think this has smaller turbo, so, should spool faster. On our small cars, this may not matter much.
Ej20 K
About 280Hp, center mounted coil (dual) and uses wasted spark. I think this has larger turbo. Not sure. I have been using wikipedia for a resource, and there is not a whole lot of detail.
As near as I can tell, I will need to get an external ignitor for either of these. Can someone jump in and clear this up?
I appreaciate any help on this.
-- brett
GS Guy
post Mar 29 2010, 10:19 AM
Be sure to add up all the costs before deciding what to buy.
For instance, when you get the engine you're likely looking at doing some PM before you ever run it - things like timing belt and water pump change (at a minimum). If any of the belt idlers are rough you'll need those too. A few gaskets, possibly a t-belt cover or two if they're damaged. All that "small" stuff adds up fast! On top of that, you may find most all the rubber hoses hard as a rock and needing replacement - and generally unavailable from US sources (IAC, emission and oil cooler hoses). Lots of short little multiple-elbow pieces not easy to find a convenient replacement for.
I think Outfront has motors with all (or most?) of this maintenance stuff already done, plus tested good compression and overall check-out. Already being in CA - I'd talk with them first to see what they have that is comparable. You might have to source the trans separately, but that'll be much less to ship.
Jeff
bfrymire
post Mar 29 2010, 12:48 PM
Salsaholic
QUOTE(GS Guy @ Mar 29 2010, 09:19 AM) *
Jeff
I spoke to the guy at Outfront about motors, and it still seems the best bet is to buy the JDM and get the parts from Outfront to refresh gaskets, belts, etc.
The trans I don't care about, and will probably sell it as I am using the Renegade kit.
Thanks for the input!
-- brett
bfrymire   Which JDM Subaru motor to use for conversion?   Mar 27 2010, 06:57 PM
dr914@autoatlanta.com   ask greg dundero he regularly posts to this site. ...   Mar 27 2010, 08:14 PM
DBCooper   I can't help as to which motor is better, but ...   Mar 28 2010, 03:32 PM
bfrymire   I can't help as to which motor is better, but...   Mar 28 2010, 05:42 PM
d914   lots of questions on the K and longivity.... I hav...   Mar 28 2010, 04:08 PM
bfrymire   lots of questions on the K and longivity.... I ha...   Mar 28 2010, 05:46 PM
bfrymire   Ok. So, I am thinking of getting this motor: htt...   Mar 28 2010, 09:45 PM
GS Guy   Be sure to add up all the costs before deciding wh...   Mar 29 2010, 10:19 AM
bfrymire   Be sure to add up all the costs before deciding w...   Mar 29 2010, 12:48 PM
DBCooper   I second that, research it well. There are lots o...   Mar 29 2010, 11:19 AM
bfrymire   I second that, research it well. There are lots ...   Mar 29 2010, 12:50 PM
pktzygt   I have an EJ20G but it's one of the varients w...   Mar 29 2010, 12:21 PM
bfrymire   I have an EJ20G but it's one of the varients ...   Mar 29 2010, 12:55 PM
pktzygt   I have an EJ20G but it's one of the varients...   Mar 29 2010, 08:12 PM
r_towle   can you flip the ring and pinion in a subaru trann...   Mar 29 2010, 08:24 PM
bfrymire   can you flip the ring and pinion in a subaru tran...   Mar 29 2010, 08:41 PM
DBCooper   can you flip the ring and pinion in a subaru tra...   Mar 29 2010, 09:39 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:42 AM
