Freedom |
Member ![]() ![]() Group: Members Posts: 79 Joined: 26-February 04 From: Colorado Member No.: 1,722 ![]() |
well first of all i replaced all of the vacuum lines, ran some injector clearer through it and checked the timing and replaced the plugs, points and wires, cap rotor...blah blah blah... i cannot figure out whant next. i took the TB off and cleaned it removed the decel valve it ran worse. and got rid of the emissions canister.. what next before i go out of my mind!!.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Fuel injection trigger points are in the lower part of the distributor. they control the pulse of the injectors. faulty or dirty injector points can cause the problems you are having. Tps needs to set with an ohm meter, but they can be set "close" without one.
Lo-Fi Version | Time is now: 3rd July 2025 - 02:13 AM |
