> sputtering 1.7 FI, what do i need to do
Freedom
post Mar 2 2004, 09:45 PM
well first of all i replaced all of the vacuum lines, ran some injector clearer through it and checked the timing and replaced the plugs, points and wires, cap rotor...blah blah blah... i cannot figure out whant next. i took the TB off and cleaned it removed the decel valve it ran worse. and got rid of the emissions canister.. what next before i go out of my mind!!.
Freedom
post Mar 2 2004, 11:19 PM
where can i get trigger points?... and also what should i set the tps at?
Freedom   sputtering 1.7 FI   Mar 2 2004, 09:45 PM
vsg914   What exactly is it doing? sputtering is kinda gene...   Mar 2 2004, 09:55 PM
Freedom   i replaced the points. the car is really under po...   Mar 2 2004, 10:01 PM
nebreitling   ignition points or fuel injection trigger points? ...   Mar 2 2004, 10:05 PM
vsg914   Hmm, have you set the dwell with a meter? Sounds l...   Mar 2 2004, 10:06 PM
JOHNMAN   If you believe it is a fuel problem, have you chec...   Mar 2 2004, 10:12 PM
garyh   I had a similar problem. Turned out to be two clo...   Mar 2 2004, 10:13 PM
weird_looking_cactus   haha sounds like my car when I had it running I ju...   Mar 2 2004, 10:15 PM
vsg914   fuel pressure=29psi. Sounds electrical to me.   Mar 2 2004, 10:16 PM
garyh     Mar 2 2004, 10:16 PM
Freedom   pulled the TPS it seemed okay i cleaned it out all...   Mar 2 2004, 10:32 PM
vsg914   Fuel injection trigger points are in the lower par...   Mar 2 2004, 10:39 PM
nebreitling   yup, triggerpoints could cause your problems. pul...   Mar 2 2004, 10:48 PM
Freedom   where can i get trigger points?... and also what s...   Mar 2 2004, 11:19 PM
nebreitling     Mar 2 2004, 11:42 PM
garyh     Mar 3 2004, 12:15 AM
JOHNMAN   I just had a strange notion and don't know if ...   Mar 3 2004, 12:17 AM
rhodyguy   kris, do you have the plug wires on in the correct...   Mar 3 2004, 08:45 AM
Dave_Darling   The Crane for the 009 distributor may or may not w...   Mar 3 2004, 11:52 AM
Freedom   well i adjusted the valves when i got the car, cha...   Mar 3 2004, 04:14 PM
Dave_Darling     Mar 3 2004, 04:59 PM
Nemo914   Non an expert here, but when my car had a similar ...   Mar 3 2004, 06:07 PM
Freedom   checked the FP and it is holding at 29psi... the ...   Mar 5 2004, 04:18 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 02:20 AM
