| 70_914 |
Mar 29 2010, 11:24 AM
Member ![]() ![]() Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
So I took my Mahles off my 74 and to Les Schwab to get the ratty tires removed so that I can refinish the wheels. They "were" straight, not badly rashed wheels set up for hub centric front disks. I drop the wheels off with my DD with plans to get everything picked up after they close because I had stuff to do. That is when things go horribly wrong.
1. When I pick up my car I check the trunk and they did not remove the weights or stems like I asked. Small deal. 2. I get to keep the 10 year old (IMG:style_emoticons/default/stromberg.gif) tires apparently, because they are in the trunk with the wheels. Little bigger deal. 3. Sunday morning I am fired up to start working on my wheels. I unload the tires and chuck them in my junk car part pile. I grab a wheel in each hand and head to the "garage" when I notice a shiny spot on the back of a wheel. The stupid friggin' tire monkey hit my wheel with the tire machine! There is a huge deviation on the back lip of the wheel. Now I have 3 wheels that are straight and not curbed up, 5 original center caps, 1 wheel that is garbage. (IMG:style_emoticons/default/piratenanner.gif) I am SO pissed and needed to vent before I throw the wheel at the store manager (I used to work there, also....) Now I get to try and convince the store manager that those dirty oxidized wheels that were sitting out for 5 years are actually 36 year old Porsche wheels that are hard to find, and would have refinished just fine. |
| bandjoey |
Mar 30 2010, 10:18 AM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
What's the difference between an American and Euro Machine and how can I tell the difference? Thanks for this info.
This should go into a tech article - about the process of getting tires installed correctly and wheels balanced. (IMG:style_emoticons/default/type.gif) |
| 70_914 |
Mar 30 2010, 11:31 AM
What's the difference between an American and Euro Machine and how can I tell the difference? Thanks for this info. This should go into a tech article - about the process of getting tires installed correctly and wheels balanced. (IMG:style_emoticons/default/type.gif) http://www.hunter.com/PUB/company/news/pre...ve/prTC3250.htm This is an ok euro machine. These tire machines do not touch the wheel lip while they are breaking the bead or while they are removing/installing the tire onto the wheel. The center arm comes down and floats just over the lip, that is what you rest the tire spoon on. That roller helps push the stiff sidewall down so it does not rip while going over the wheel edge. These machines are required for any of the nicer wheels- anything over 17" diameter, anything below 50 series, anything with a large polished lip or a strange offset that causes the tire to need to come off the wheel from the back. |
70_914 I am effin pissed Mar 29 2010, 11:24 AM
effutuo101 ouch! that sucks. Do like the little old lady.... Mar 29 2010, 11:38 AM
tradisrad That is a bummer. Just keep your cool with the sto... Mar 29 2010, 11:40 AM
kwales That sucks.
I had a tire store bend the rim on on... Mar 29 2010, 12:29 PM
Root_Werks I have found that Less Schwab pretty much has noth... Mar 29 2010, 12:37 PM
zymurgist Babydoll got her center caps mangled by tire monke... Mar 29 2010, 02:18 PM
Root_Werks I should note that I haven't been to a LS in a... Mar 29 2010, 02:32 PM
tod914 Had the tire guy beat the crap out of my center ca... Mar 29 2010, 02:45 PM
naro914 We have a guy here in Charlotte that knows good wh... Mar 29 2010, 04:10 PM
Phoenix 914-6GT We have a couple like that here. They have a side ... Mar 29 2010, 04:18 PM
carr914
Babydoll got her center caps mangled by tire monk... Mar 29 2010, 05:12 PM
zymurgist
Babydoll got her center caps mangled by tire mon... Mar 30 2010, 04:44 AM
Rav914
We have a couple like that here. They have a side... Mar 29 2010, 08:07 PM
jmill LS isn't the only place messing up rims. I ha... Mar 29 2010, 09:15 PM
naro914 What I can't believe is that all of you are sh... Mar 30 2010, 10:59 AM
70_914
What I can't believe is that all of you are s... Mar 30 2010, 11:25 AM
Root_Werks I also once caught a tire-monkey hammering one of ... Mar 30 2010, 11:53 AM
scotty b I drive 30 minutes to get my tire work done. Only ... Mar 30 2010, 01:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:14 AM |
