Intermittant spark, Could this be my pertronix? |
zehrschnell914 |
Mar 3 2004, 09:39 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
After all of the problems (all electrical) I've had with this car, it died on me again. Turned over and all other electrical worked (including fuel pump), but wouldn't start. Guessed no spark and had it towed home.
Next day I pulled the coil wire to check it and it had great spark. I turned the key and it fired right up. I let it run for 10 minutes then backed it out of the garage and it died again. Pulled the coil wire off and had the lovely wife (IMG:style_emoticons/default/wub.gif) crank it over again and got nothing! All of the ignition components are new and I have installed a Pertronix kit. I looked for the points that came with the dizzy, but couldn't find them. Any ideas? Mike |
need4speed |
Mar 3 2004, 10:40 AM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
Gremlins.
It's gotta be those damn Gremlins. Kit; would you recommend a separate external ground wire from an external screw on the dizzy (maybe one holding the vacuum can in) to a bolt on the case - perhaps to clarify the ground signal some? I have habitually left my dizzy clamp slightly loose in order to facilitate the constant tweaking and adjusting, but I've also always suspected that some of my problems are from intermittent spark - due to either condensation or dirt or just plain bad luck, or possibly crappy condensers - so if it's been a grounding problem all along for me, do you think the addition of such a wire would clear it up? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:37 PM |
