Intermittant spark, Could this be my pertronix? |
zehrschnell914 |
Mar 3 2004, 09:39 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
After all of the problems (all electrical) I've had with this car, it died on me again. Turned over and all other electrical worked (including fuel pump), but wouldn't start. Guessed no spark and had it towed home.
Next day I pulled the coil wire to check it and it had great spark. I turned the key and it fired right up. I let it run for 10 minutes then backed it out of the garage and it died again. Pulled the coil wire off and had the lovely wife (IMG:style_emoticons/default/wub.gif) crank it over again and got nothing! All of the ignition components are new and I have installed a Pertronix kit. I looked for the points that came with the dizzy, but couldn't find them. Any ideas? Mike |
McMark |
Mar 3 2004, 07:59 PM
I have installed 3 or 4 Pertronix over the last six months, and I have no complaints about the fit. The magnet ring takes a little while to seat down fully, but if you're persistent it always will and you don't have to modify your rotor. I've always gotten the rubber grommet into the hole in the body. Everything works right, it just takes time and patience to make it fit right.
Lo-Fi Version | Time is now: 2nd June 2024 - 02:41 AM |
