Intermittant spark, Could this be my pertronix? |
zehrschnell914 |
Mar 3 2004, 09:39 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
After all of the problems (all electrical) I've had with this car, it died on me again. Turned over and all other electrical worked (including fuel pump), but wouldn't start. Guessed no spark and had it towed home.
Next day I pulled the coil wire to check it and it had great spark. I turned the key and it fired right up. I let it run for 10 minutes then backed it out of the garage and it died again. Pulled the coil wire off and had the lovely wife (IMG:style_emoticons/default/wub.gif) crank it over again and got nothing! All of the ignition components are new and I have installed a Pertronix kit. I looked for the points that came with the dizzy, but couldn't find them. Any ideas? Mike |
anthony |
Mar 3 2004, 08:04 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Did you put them into a 2L distributor? There is no way the gromet I got would fit in the hole.
I will also add that I disassembled the top end of my 30 year old distributor, cleaned out all the gunk, regreased it, and operation improved 100%. My jumpy timing completely dissappeared. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:50 PM |
