Steering wheel shakes, Need to pick ur knowledge |
SUNAB914 |
Apr 6 2010, 08:51 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Ok, 74 that has steering wheel shaking when reaching speeds of 55mph or more. I have changed the tie rods, struts, ball joints are good although I have new ones standing by. Front wheels are getting eaten on inside of tire. I wasn't able to check alignment due to the alignment tool was broken at the place I went, but they will have a new one in the next few days. I will take it back to recheck. Everything is tight and can't figure out why it is doing this, so far. Before I left we, rotated rear tires up front, but it still has the shaking, not as bad but there. Tires are dead on balanced and they are new. 4000 miles on on four.
What do I look for next? Thanks for your input. |
Mike Bellis |
Apr 6 2010, 09:30 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I would have another shop ballance the tires. It could be non hub centric wheels too. See if the shop can ballance with the lug pattern and not the hub. It may be ballanced to zero at the hub and you need it ballanced zero at the lugs. If it is only shaking at 55mph, I think it's still the ballance. even though you may still have an alignment issue.
Lo-Fi Version | Time is now: 8th June 2024 - 12:23 AM |
