Steering wheel shakes, Need to pick ur knowledge |
SUNAB914 |
Apr 6 2010, 08:51 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Ok, 74 that has steering wheel shaking when reaching speeds of 55mph or more. I have changed the tie rods, struts, ball joints are good although I have new ones standing by. Front wheels are getting eaten on inside of tire. I wasn't able to check alignment due to the alignment tool was broken at the place I went, but they will have a new one in the next few days. I will take it back to recheck. Everything is tight and can't figure out why it is doing this, so far. Before I left we, rotated rear tires up front, but it still has the shaking, not as bad but there. Tires are dead on balanced and they are new. 4000 miles on on four.
What do I look for next? Thanks for your input. |
Jeffs9146 |
Apr 6 2010, 10:45 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE Everything is tight and can't figure out why it is doing this, so far. OK I got this one!! I was haveing this problem and I tried everything until I got frusterated and just put two new tires on the front! Wow problem solved, it turned out that the car had been sitting so long on the ground that the tires had a flat spot on them! Jack stands are your friend when you are storing a car for long periods of time! |
Lo-Fi Version | Time is now: 7th June 2024 - 11:05 AM |
