Intermittant spark, Could this be my pertronix? |
zehrschnell914 |
Mar 3 2004, 09:39 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
After all of the problems (all electrical) I've had with this car, it died on me again. Turned over and all other electrical worked (including fuel pump), but wouldn't start. Guessed no spark and had it towed home.
Next day I pulled the coil wire to check it and it had great spark. I turned the key and it fired right up. I let it run for 10 minutes then backed it out of the garage and it died again. Pulled the coil wire off and had the lovely wife (IMG:style_emoticons/default/wub.gif) crank it over again and got nothing! All of the ignition components are new and I have installed a Pertronix kit. I looked for the points that came with the dizzy, but couldn't find them. Any ideas? Mike |
McMark |
Mar 3 2004, 11:25 PM
More likely a pertronix than a coil. The only test is to replace it. (IMG:style_emoticons/default/sad.gif) Did you check for 12v at the coil? Could be an ignition switch going out.
You don't have spare coils? Isn't everybody supposed to have loads of spare parts? I was pulling some engine parts for my crank (at the machine shop getting balanced) and pulled out one of my engine boxes. There was 4 engines worth of misc pieces in there!! How the heck did I get so much crap? Nice to have though. I also found a never cut flywheel (I had 5 spare flywheels at my storage place) so I can stop worrying about my nearly gone flywheel. SCORE! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:32 AM |
