Intermittant spark, Could this be my pertronix? |
zehrschnell914 |
Mar 3 2004, 09:39 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
After all of the problems (all electrical) I've had with this car, it died on me again. Turned over and all other electrical worked (including fuel pump), but wouldn't start. Guessed no spark and had it towed home.
Next day I pulled the coil wire to check it and it had great spark. I turned the key and it fired right up. I let it run for 10 minutes then backed it out of the garage and it died again. Pulled the coil wire off and had the lovely wife (IMG:style_emoticons/default/wub.gif) crank it over again and got nothing! All of the ignition components are new and I have installed a Pertronix kit. I looked for the points that came with the dizzy, but couldn't find them. Any ideas? Mike |
zehrschnell914 |
Mar 3 2004, 11:45 PM
QUOTE More likely a pertronix than a coil. The only test is to replace it. Did you check for 12v at the coil? Could be an ignition switch going out. I just replaced the ignition switch (had some burnt wires under the dash...), but I didn't remember to check for power to the coil (IMG:style_emoticons/default/blink.gif) Glad to hear about your spare flywheel Mark! I'm gonna go buy a new coil after I check to make sure it's getting 12v. Mike |
Lo-Fi Version | Time is now: 9th June 2024 - 04:30 PM |
