Now we have Startie- but the idle is way off, Anybody have a flow chart for D-Jet like PBAnders Fuel Pump flow chart |
Jona Gold |
Apr 5 2010, 07:55 PM
The Righteous are as Bold as a Lion Group: Members Posts: 45 Joined: 20-March 06 From: Central Minnesota Member No.: 5,745 Region Association: Northstar Region |
This winter I pulled the motor and transmission out of my 70- to fix the transmission issue I was having. I bought a good transmission after running out of time before spring (I was working on rebuilding a side shift) and put it on and reinstalled the motor.
I hooked up everything just as it was- but now it won't start. I have fuel, I have spark, it cranks over strong, but it won't ignite. So far I have gone through the 12 pin wiring harness for ignition (starter, backup lights, Air Sensor, Oil Pressure switch, Coil, and Fan). I rebuilt it since there were small breaks here and there. I replaced the points & condensor. Gapped the points appropriately.... (.016in). Can you plug any of the FI wiring in backwards? Everything kind of just fell back into place since it's been that way for 40 years. It would feel awkward to plug something in wrong. The car started immediately before and ran near perfect (best running 914 I've owned yet)- now it won't start. I did replace the fuel lines while I was in there as well (they were old). Any ideas? What could I be missing? |
Jona Gold |
Apr 6 2010, 07:01 PM
OK- so it's no fuel now.
What's odd is- it got fuel fine when I started this- but now the fuel pump doesn't even come on with the key. I hear it making clicking noises as I try to start the car, but no fuel comes out of the injectors. Fuel lines are not crossed- I double checked with the book. Head temp, manifold pressure- both good. Wiring appears to be all in tact, and in the right places, the 12 and 14 pin connectors are spot on and I even tried a known good relay for the fuel injection. So that's where I'm at- no noise from the fuel pump except the clicking. No fuel from the injectors.... Back to scratching my head - and maybe another beer.... |
Lo-Fi Version | Time is now: 11th June 2024 - 08:03 PM |
