OT: Any Fluid Handling experts here?, Small scale engineering help requested |
lotus_65 |
Apr 8 2010, 10:08 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
Hi good people, you are the best resource I have at hand, so I'm throwing this out to you all:
At work, I/we utilize 2-2.5 gallon pressure pots that hold 2 similar liquid (gloss & matte) materials (basically glue) that we use to coat our products with an hvlp gun using 10lbs pressure in our spray booth. Some clients want a combination of the 2 coatings to create a 3rd semi-gloss/satin finish. Best case scenario is that I could mix/blend the 2 in-line somehow, because we could easily customize the coatings per the client's request. It's logical to me to relate these 2 liquids as something similar to hot and cold water, and I want to be able to coat my products with hot, warm or cold liquid using a manifold to dial the percentages. As I'm writing this, I feel like it would be ideal to have some type of ball valve at the gun, receiving the two fluid lines, and allowing me to dial the mix right there. Does anyone know what I'm trying to say, and have a direction to share? Thanks- paul |
Porcharu |
Apr 8 2010, 09:51 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I used to deal with picoliters - a couple of gallons is WAY out of my league.
Steve |
Lo-Fi Version | Time is now: 11th June 2024 - 02:31 PM |
