Engine Not Running Right, Appears to be running on 2 cylinders?? |
LotusJoe |
Apr 9 2010, 10:24 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I removed all the tins and blower case to clean the cylinder fins and head fins, and replaced the oil cooler seals. I also changed the plugs, points, rotor, cap, and plug wires. Put everything back together and started it up. Set the timing and the engine appears to run correctly. I got out my Raytech temperature gun to check the exhaust pipe temps at the head. Cylinders 1 and 3 run about 450 degrees at the exhaust pipe where it connects to the head. Cylinders 2 and 4 are running 140 degrees. This tells me there is no fire in Cylinders 2 and 4.
Not sure on where to start checking. I'm thinking 2 and 4 are not getting fuel? Could there be a problem with the control module in the bottom of the distributor? If so how do I check it? A few months ago I did a compression check and got 165 on all four cylinders. Engine idles fine and revs smoothly. It's on a test bench so obviously there is no load on the motor. Would it run smooth on just cylinders 1 and 3? |
Tom |
Apr 10 2010, 08:52 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Your cap is wire different than mine (90 dergees different). Number one, I think, should come out of the cap just to the rear of the vacuum can on the dissy. Then going clockwise for firing order. Maybe your timing is different?
Tom |
LotusJoe |
Apr 10 2010, 08:59 AM
Your cap is wire different than mine (90 dergees different). Number one, I think, should come out of the cap just to the rear of the vacuum can on the dissy. Then going clockwise for firing order. Maybe your timing is different? Tom Would it even run if I was 90 degrees out (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:16 PM |
