> Now we have Startie- but the idle is way off, Anybody have a flow chart for D-Jet like PBAnders Fuel Pump flow chart
Jona Gold
post Apr 5 2010, 07:55 PM
The Righteous are as Bold as a Lion
This winter I pulled the motor and transmission out of my 70- to fix the transmission issue I was having. I bought a good transmission after running out of time before spring (I was working on rebuilding a side shift) and put it on and reinstalled the motor.
I hooked up everything just as it was- but now it won't start.
I have fuel, I have spark, it cranks over strong, but it won't ignite.
So far I have gone through the 12 pin wiring harness for ignition (starter, backup lights, Air Sensor, Oil Pressure switch, Coil, and Fan). I rebuilt it since there were small breaks here and there.
I replaced the points & condensor. Gapped the points appropriately.... (.016in).
Can you plug any of the FI wiring in backwards? Everything kind of just fell back into place since it's been that way for 40 years. It would feel awkward to plug something in wrong.
The car started immediately before and ran near perfect (best running 914 I've owned yet)- now it won't start. I did replace the fuel lines while I was in there as well (they were old). Any ideas? What could I be missing?
Jona Gold
post Apr 10 2010, 06:17 PM
I just ran it with every vacuum line on....idle is 33-3400rpm Idle screw makes no difference. (minus the missing AAR and decel valve of course - those lines I plugged).
I unplugged the ports that go to the AAR- no change.
I remove every flippin' vacuum line on the engine starting with the MPS one line at a time...no change.
WTF?
How did this thing run great last fall with bad grounds and cracked vacuum lines? As far as FI & vacuum goes, I've changed nothing. I did fix a lot of broken wires and replace the relay board. So doing those "repairs" have now rendered me disabled.....
Jona Gold   Now we have Startie- but the idle is way off   Apr 5 2010, 07:55 PM
realred914   timing way off, spark plug wires mixed up are my f...   Apr 5 2010, 08:08 PM
76-914   You said you R&R'd the fuel lines. Did you...   Apr 5 2010, 08:14 PM
Jona Gold   Timing and plug wires were never changed. I pulle...   Apr 5 2010, 09:39 PM
r_towle   you smell fuel? then its ignition. Check all the ...   Apr 5 2010, 10:02 PM
Rand   Everything said is right on. You say you have fuel...   Apr 5 2010, 10:41 PM
Jona Gold   I checked spark with a spark tester- you hook your...   Apr 5 2010, 11:04 PM
markb   Trigger points plugged in?   Apr 5 2010, 11:10 PM
Jona Gold   Yes- the trigger points are plugged in. I had tha...   Apr 5 2010, 11:14 PM
kkid   Did you hook up the fuel lines in the engine compa...   Apr 6 2010, 12:10 AM
vsg914   Two things. First, as mentioned, is crossed fuel l...   Apr 6 2010, 06:41 AM
Jona Gold   OK- so it's no fuel now. What's odd is- i...   Apr 6 2010, 07:01 PM
vsg914   No fuel pump running. Key switch (seems to have be...   Apr 7 2010, 06:41 AM
ericread   Aha! You need the pbanders ( :worship: ) fuel...   Apr 7 2010, 12:52 PM
Jona Gold   The PBAnders Flow chart got me solved... I got to ...   Apr 10 2010, 12:25 PM
Tom   Could be that the PO tuned it with some wire broke...   Apr 10 2010, 12:31 PM
Jona Gold   Not the idle screw- bummer..... Still trying to g...   Apr 10 2010, 03:06 PM
vsg914   High idle could be a vacuum leak. are all the exrt...   Apr 10 2010, 03:11 PM
Jona Gold   My idle is between 3500 and 5000 depending on weat...   Apr 10 2010, 04:08 PM
tod914   Timing too far advanced maybe? If you line up the...   Apr 10 2010, 04:10 PM
Jona Gold   This is the second time I've been up against s...   Apr 10 2010, 04:15 PM
Jona Gold   Can anybody point me to a good vacuum diagram for ...   Apr 10 2010, 04:46 PM
BiG bOgGs   http://www.pelicanparts.com/914/technical_...4_17F...   Apr 10 2010, 04:54 PM
gasman   Don't forget the AAR....this is a controled va...   Apr 10 2010, 05:19 PM
Jona Gold   The AAR.... How the hell did the PO get this car ...   Apr 10 2010, 05:51 PM
Jona Gold   I just ran it with every vacuum line on....idle is...   Apr 10 2010, 06:17 PM
pbanders   Sounds like a vac leak. Lots of places to check. S...   Apr 10 2010, 06:20 PM
1988Hawk   I would also suggest reinstalling your injectors w...   Apr 10 2010, 06:22 PM
Jona Gold   Where's the best place to get new injector sea...   Apr 11 2010, 07:33 PM
Jona Gold   PBAnders! :worship: Thanks a ton- your Fue...   Apr 11 2010, 07:34 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:05 AM
