suspension/tire pressure adjustments, Getting ready for nex AX |
mikelsr |
Apr 8 2010, 10:46 AM
Senior Member Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I used to have a chart that told me what to adjust for what conditions and the site that had it doesn't exist any more (and I can't find the printout). Since the cancer was removed on my car and the Engman inner stiffener and the Brad M. outer stiffeners installed, my car has become extremely stiff. So I need to start from scratch adjusting shocks, tire pressures and anti-sway bar. I didn't have to do this earlier since the PO had the car set up and gave me settings and it worked. I tried them a couple of weeks ago and they don't work any more.
Does anyone have a chart that shows what adjustments to make when a car is loose, tight, etc? I have Koni yellows, stock rear anti-sway bar, a 19mm front anti-sway bar, and 180lb progressive springs. My tires are Kuhmo ecsta v700 205 50x15 and 225 45x15. Front rims are 7" and rears are 8". Oh and the car is a 1970 914-6 with a 2.7L RS'ish engine. And I did search the archives but didn't find what I was looking for. Thanks in advance. Mike P.S. Here is my car in action a couple of weeks ago. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-3390-1270745183.1.jpg) |
6freak |
Apr 12 2010, 10:32 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
tire pressure seems a little low ....maybe try 26 front 27 back depends on the tire though .....if you like it the way it is leave it ...I would try and disconnect rear sway bar ! it will rotate better for you ...good luck have fun and be safe
Mike C |
Lo-Fi Version | Time is now: 10th June 2024 - 10:39 AM |
