| VaccaRabite |
Apr 13 2010, 07:45 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,916 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Last fall, the drivers side headlight went out. it was miswired - I am not sure how it was working to begin with. Fixed the wiring, and everything worked great.
Saturday I washed my car. Today, I decided to drive to work, even though rain was threatening, weather said I would be clear. But it was cloudy this morning, so I put the lights on. I got no beam from the drivers side light, again. Also, I noticed that the charging system was right at 12 volts, where it is usually at 13. May be unrelated. I know that the wiring at the light is correct. Any idea where to start trouble shooting? Zach |
tradisrad I also see a voltage drop when my lights are on fr... Apr 13 2010, 07:49 AM
underthetire I've had a problem with my old sealed beams be... Apr 13 2010, 11:11 AM
jsayre914 dont woory about the voltage drop zach, it isnt a ... Apr 13 2010, 12:07 PM
Vacca Rabite Mike may be over today. He was planning on being o... Apr 13 2010, 12:10 PM
TROJANMAN Did you check the relay? Apr 13 2010, 12:20 PM
Drums66
ECHO echo(also headlig... Apr 13 2010, 12:43 PM
Vacca Rabite Not yet. Noticed the light was out when I pulled ... Apr 13 2010, 12:24 PM
Spoke Start checking voltages right at the light.
If yo... Apr 13 2010, 02:32 PM
Vacca Rabite When I got home tonight I took a few minutes to tr... Apr 13 2010, 07:03 PM
Dave_Darling Sounds like the brighter light is grounding itself... Apr 13 2010, 09:10 PM
Vacca Rabite Dave, I considered this. I think it is probably t... Apr 14 2010, 06:06 AM
Vacca Rabite Okay, so new puzzle.
I fixed the first problem. ... Apr 16 2010, 08:41 PM
Dave_Darling How did you measure the voltage? Between which an... Apr 16 2010, 09:20 PM
Vacca Rabite I measured voltage at the headlight terminals.
Wh... Apr 17 2010, 06:52 AM
Vacca Rabite Well, Mike helped me chase the problem, and we fou... Apr 19 2010, 08:08 AM
Vacca Rabite So, this problem still exists.
I had been letting... May 24 2010, 09:47 PM
Spoke
Low beams are only getting 6 volts at the bulb.
... May 25 2010, 11:12 AM
Dr Evil Maybe I can help you out sometime :rolleyes: May 24 2010, 11:06 PM
Vacca Rabite
Did... May 25 2010, 06:29 AM
Dr Evil I remember nothing. I would have to start at it so... May 25 2010, 09:41 AM
Vacca Rabite One test that I am going to do this evening, which... May 25 2010, 01:11 PM
Vacca Rabite Just finished my wire test.
Everything from the fu... May 25 2010, 06:20 PM
Dr Evil I may have a spare. I know where I can get one, an... May 25 2010, 06:45 PM
Spoke Disconnect NEG from Battery and pull out your swit... May 25 2010, 08:38 PM
Vacca Rabite I'm back inside for the night, and I made prog... May 25 2010, 08:57 PM
Spoke I wouldn't expect a rubbed wire or anything li... May 25 2010, 10:11 PM
Vacca Rabite I'll clean them tonight and report back.
I am ... May 26 2010, 06:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 03:13 AM |
