Weber carbs, What's the difference? |
914 Monster |
Apr 13 2010, 09:13 PM
Newbie Group: Members Posts: 27 Joined: 14-April 08 From: Los Angeles Member No.: 8,924 Region Association: Southern California |
Since I'm in the process of rebuiling my 2.0 engine, I was wondering why 914 high performance engines use 44 IDF carbs instead if 48 IDF's or IDA's. I'm not trying to build a race car or anything to much but want to upgrade my 40 IDF's.
GeorgeRud |
Apr 13 2010, 09:22 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Don't go too large on the venturi diameter, or you will not have enough of a "pulse" at idle and at low rpms! There is a formula that has been used to try to match the size to the size of the engine. The factory 914-6 engines came with 40mm diameter throttle bodies, but all the way down to 27mm venturis (to get a good enough signal for emission control at idle).
The 44s and 48s are usually best for race engines that will be run at high revs, not for street cars INHO. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:18 PM |
