MY TEENERS GONE LAME! II an update, Beginning to doubt cv's are the cause |
rascobo |
Apr 14 2010, 08:25 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
I previously posted in 'My teeners gone lame' that I had a bad cv joint; Now I'm not so sure. I based it on the fact that I could hear and feel a rotational clunking in the rear, but its not like a bad joint so much as one that has come completely free of the stub axle and is slamming around inside the trailing arm. I checked and all joints were tight and neither axle had any play in them. Then I thought I had blown out the wheel bearing(s) as I forgot to tighten the axle nuts before the 1st test drive. I tightened the axle nuts, raised the rear and found no play in the wheels, so I tried driving it again, but still have the loud clunk and jolt on each rotation of the wheels. Before I start tearing everything down, does anyone have any idea as to what might be causing this?[b]
brp986s |
Apr 14 2010, 08:42 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I previously posted in 'My teeners gone lame' that I had a bad cv joint; Now I'm not so sure. I based it on the fact that I could hear and feel a rotational clunking in the rear, but its not like a bad joint so much as one that has come completely free of the stub axle and is slamming around inside the trailing arm. I checked and all joints were tight and neither axle had any play in them. Then I thought I had blown out the wheel bearing(s) as I forgot to tighten the axle nuts before the 1st test drive. I tightened the axle nuts, raised the rear and found no play in the wheels, so I tried driving it again, but still have the loud clunk and jolt on each rotation of the wheels. Before I start tearing everything down, does anyone have any idea as to what might be causing this? Maybe your 1st gear backed off. |
rascobo |
Apr 14 2010, 08:59 PM
I previously posted in 'My teeners gone lame' that I had a bad cv joint; Now I'm not so sure. I based it on the fact that I could hear and feel a rotational clunking in the rear, but its not like a bad joint so much as one that has come completely free of the stub axle and is slamming around inside the trailing arm. I checked and all joints were tight and neither axle had any play in them. Then I thought I had blown out the wheel bearing(s) as I forgot to tighten the axle nuts before the 1st test drive. I tightened the axle nuts, raised the rear and found no play in the wheels, so I tried driving it again, but still have the loud clunk and jolt on each rotation of the wheels. Before I start tearing everything down, does anyone have any idea as to what might be causing this? Maybe your 1st gear backed off. Huh? Whats that mean? |
JRust |
Apr 14 2010, 09:04 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
PM sent. give me a call
Does it make this noise just pushing the car in neutral? Does it make it on blocks with the wheels off the ground? |
Lo-Fi Version | Time is now: 11th June 2024 - 01:09 PM |
