What The Heck Do I Do Now?, I hate electrical |
fly |
Apr 14 2010, 11:57 AM
Newbie Group: Members Posts: 38 Joined: 8-September 03 From: Walnut Creek, CA Member No.: 1,119 |
Here is a good one for all of you electrical masters. The starter on my car went out when the bendix stayed engaged. SO. I put in the new starter, new battery. This is a 75 1.8 with the 2.0 starter (the one with out the shaft).
New starter installed the car turned over well. Cranked 5 or 6 times while the fuel pump fed the injectors. Immediately turned the key to start the 2nd time and nothing happened. Basically what i have is a car that will start 5% of the time on its own. 95% you just hear the feul pump working. Tested all the wires with a friend who seems to understand more than I do. The yellow wire on the starter shows 12.7 volts when the key is engaged. Under a load it drops to 9.7 volts. Is this enough to close the circuit on the starter? Does the Yellow wire go direct from the key switch to the starter? I thought about replacing the entire harness. We bypassed the ignition and the same results. How is it possible for the car to randomly start perfect, then nothing for the next 20 tries? Has anyone had this experience? I am out of ideas and tests to perform. Or does anyone want to buy a clean 75 Any help will be greatly appreciated Mike 925-705-2030 |
Gint |
Apr 15 2010, 05:44 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Beautiful car!
It's never a bad idea to check and clean grounds in a 914 when you have an electrical issue. Based on what you've said here though, it sounds like the electrical portion of your ignition switch. As someone already mentioned, turn the key on and get a remote starter switch and see if the car starts. If it does so consistently, replace the ignition switch. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:58 PM |
