| scoobykvn |
Apr 4 2010, 12:33 PM
Member ![]() ![]() Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
I have a 1970 1.7 and I need help. The first problem is my starting issue. I replaced the ignition switch and checked all connections and have found no issues. When I turn the key I get the oil light on and fuel pump running like normal. When I turn the key to start I get the oil light to go off and the fuel pump to run. All I get out of the starter is a click, most of the time. Every once in a while it cranks and starts right up. The starter is also new.
Now, once it starts I can't keep it running. Previously I could get it to stay running and it would run very high rpm for about 30 seconds then start to fluctuate and eventually die. I replaced all of the vacuum lines and now when it starts it will only run for a few seconds. My guess is the tuning is way off. If this is the case, how do I find a good starting tuning point so I can keep it running in order to fine tune it? It is still fuel injected and all standard tune-up components replaced. |
| scoobykvn |
Apr 18 2010, 10:03 PM
any opinions?
scoobykvn Engine starting and running troubles Apr 4 2010, 12:33 PM
realred914
I have a 1970 1.7 and I need help. The first prob... Apr 4 2010, 02:01 PM
McMark The oil light should not go off while the key is i... Apr 4 2010, 02:09 PM
scoobykvn Update:
The oil light does not go off, I was mist... Apr 11 2010, 03:04 PM
scoobykvn Nobody has any ideas? Apr 12 2010, 04:46 PM
Kirmizi Was it having problems before you replaced the ign... Apr 12 2010, 05:29 PM
scoobykvn Yes, it was having pretty much the same problems. ... Apr 12 2010, 06:20 PM
underthetire Check your fuel pressure. Sounds like the pump isn... Apr 12 2010, 06:35 PM
scoobykvn For a temporary fix to get the car running, is the... Apr 14 2010, 11:06 AM
scoobykvn So I now have the fuel pump on a switch for troubl... Aug 1 2010, 02:05 PM
vsg914 Could be improper timing, or dwell, or maybe even ... Aug 1 2010, 02:32 PM
swl for the fuel pump. Check the fuel pump and master... Aug 2 2010, 06:09 AM
einic Check the lower points. The pump is supposed to st... Aug 2 2010, 06:57 AM
scoobykvn Checked static timing and dwell, checked pressure,... Aug 21 2010, 11:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 07:52 PM |
