SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Purpose of the car, in order:
Spirited street driving, occasional AX, occasional track days. Here's what i think i know (IMG:style_emoticons/default/biggrin.gif) LSD - Always locks wheels together under acceleration and deceleration. - Introduces understeer in slow corners. - Generally considered the better choice for the big track. TB - Only locks wheels under acceleration. - Acts like a open diff if a driving wheel is off the ground. So, the question is, what should i get for my 915??? The car will never be a dedicated track car, it's mostly driven on the street. The TB seems to be easier to drive on the street. However, the slow corner understeer of a LSD could probably be tuned down with suspension settings. The TB loses it's magick if one wheel is off the ground. In an AX setting, the suspension would need to be pretty stiff to keep both wheels on the ground at all times, would a LSD be the better choice here? Anyone compared the two back to back in a 914? (IMG:style_emoticons/default/idea.gif) Andy |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I have run both and like the LSD better in almost all cases. Most AX'ers I know like the TBD's better because they like to snap the car through AX elements when the TBD goes open on deccel. I've always thought the deccel-oversteer in a turn with a TBD is more acute, but it does make for better slalom snaps. TBD's do one more thing that's easily driven around but it's a little annoying to me.
When I accelerate in a long sweeping turn which of course, we all do, I can feel the bias changing now and then. It doesn't seem to upset the suspension (except that I can feel it) so it's just an itch. Still, it's a little like someone tapping on their glass eye while they're talking to you. It doesn't really effect you, but it has your attention. The LSD is smoother and the transition from deccel to accel causes less drama. But the LSD is gonna cost more and the maintenance is higher. The clutches and plates need to be replaced now and then based on your driving style and mileage. Of course, there is something wonderful about the TBD install-it-and-forget-it thing. There's my 2 cents. They're both good Good luck |
Lo-Fi Version | Time is now: 17th June 2024 - 11:11 AM |
