Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
I have often read on this forum that you can't evaluate rubber brake lines from the outside.
Even though the hoses on my '70 looked good, no cracks, etc., I knew they were 40 years old (they have the year of manufacture on the outside). I just replaced all four. I cut the rears with a razor knife to use a 17mm socket to remove. As I had often heard, they deteriorate and close up on the inside. I cannot blow through this one at all. I can't imagine very much fluid was flowing to the caliper, if any. As soon as I bleed them I expect a test drive to show much better brakes with less pedal effort...and have a safer car. First time I have replaced the hoses on a 914 and I have owned about 15 of them in the last 10 years! ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,371 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Boy, that scares the brake fluid out of me.
That was one of the considerations for my deciding not to try to get my six on the road for the summer. The right front brake was dragging badly and I figured the brake system needed to be completely gone through i.e., master cylinder, calipers, rotors, e-brake, and SS brake lines. So then I thought well the pedal cluster probably needs new bushings.... Then I realized the fuel system would be toast so new SS lines, tank restored, etc. Then I thought well I can't really drive it with all of the oil that is leaking out of it, and these leaks re-define the word leak; more like a severed artery-really. Then I was like well the tires are crap with sidewall rot, so some replacement tires just for the summer. When I started to do the math I was like $4K seems likely. So I decided it would be better to leave it parked and covered and just plan for the restoration in 2012..... So, my six sits in my garage where it is hibernating under a covered. If I could just hit the lotto or something I would get the restoration started immediately. I mean I am not greedy; say maybe 5 million would be good enough. Heck I might even buy another one and restore it too. Unfortunately, I have a mouth full of teeth, can read and write so probably no chance on the lotto thing. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 06:13 PM |
