Fuel Pump Diagnostics |
solex |
Mar 21 2010, 12:40 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi All,
Need a little help to diagnose a fuel pump problem in a 75, I do not hear the pump when I turn the key to the run position. The car was running, I had a few occasions where it would not start, let it sit for a few days and it was start right up. The grounds: under the relay board, battery and transmission have all been cleaned. All fuses are good. The relay is working as I can hear it click into position. When the key is in the run position relay terminals 30 and 85 shows 12 volts. Terminal 86 show 0.03 volts and terminal 87 show zero volts. There is no voltage at either of the fuel pump terminals. The readings at the relay is counter to to what Haynes states (86 should read 12 and 85 should be ground). I not sure where to check next, really do not want to pull the tank. Any assistance would be appreciated. Thanks, Dan |
solex |
Apr 25 2010, 12:03 PM
Steve, Mike,
Shorting 87 to 30 on the Fuel Pump Relay (ignition is off) activates the pump. I guess it is entirely possible that the second board I purchased is also bad, but I checked all contacts and made sure there was continuity through all of the traces I'm in the process of rebuilding my original board with hopes that the PBANDERS flow charts are pointing me in the right direction. I followed it to the letter several times and the result point to a bad relay board..... Steve thanks for the second comment re: points, I did not know that.... |
Lo-Fi Version | Time is now: 10th June 2024 - 04:20 AM |
